Hello @geowol
There’s no way to use full text search feature with PDF files since this is non-editable file format at the moment. I’m a little bit surprised that you were able to get it works on the older version of Community server. Please double check the situation and provide us with details.
This is really very easy to reproduce. Debian 10 installed without any GUI at all. Docker and Docker-Compose are installed.
Now it is enough to install Groups (docker-compose.groups.yml) according to instructions. But I also tested it with Workspace (docker-compose.workspace.yml).
cd /opt/
mkdir containers
cd containers
git clone https://github.com/ONLYOFFICE/Docker-CommunityServer
cd Docker-CommunityServer/
cp docker-compose.groups.yml docker-compose.yml
docker-compose up
After registration, I simply enabled full-text search and upload a corresponding PDF document named “Suchdokument.pdf” with the String “7777” in its content. Searched for the content “7777” and voila: found.
As I understand it, it should not matter for the search if PDF documents are editable.
If I open a PDF with Onlyoffice Docs, I can search for content in it as well.
Hello @geowol
Sorry about it. The current situation is that we removed full text search feature for pdf files in one on of the older version of Community server in order to reduce the amount of data. You are absolutely right, on older versions this feature works.
I can’t say yet if this function will be returned.
Hello again @geowol
We added your idea to internal tracklist (internal number - 54998). We will try to implement it (optional switching-on of full text search for different formats) in one of the next version of Community Server.
Unfortunately, I cannot provide you any guaranties of release of this idea at the moment.
Good morning everyone,
I realized that the full text search for PDF files does not work only today and before making a report on the Forum I wanted to check if there was already a communication made by other users.
Reading the previous posts, I regret that this feature is currently unavailable and that it is not known if it will be added in the future.
This is very disappointing to me as we use this specific function a lot in the company.
At the moment we use Alfresco and I am considering migrating to Onlyoffice, but at the moment I am honest I do not see the conditions to be able to do so.
