fromJSON won't work
window.Asc.plugin.callCommand(() => {
      var oTextForm = Api.CreateTextForm({
        key: "Personal information",
        tip: "Enter your first name",
        required: true,
        placeholder: "First name",
        comb: true,
        maxCharacters: 10,
        cellWidth: 3,
        multiLine: false,
        autoFit: false,
      oParagraph.AddElement(oTextForm);
      var json = oParagraph.ToJSON(true, true);
      var oParagraphFromJSON = Api.FromJSON(json);
      oDocument.AddElement(0, oParagraphFromJSON);
TextForm will change to InlineLvlSdt, CheckBoxForm will repeat,ComboBoxForm will not be rendered, and the ContentControlList generated by Plugin(AddContentControlList) will not be rendered
Hello @GGbeng
Do I understand it right that you’re using your own self-made plugin in this test? If so, could you please provide us with plugin example (videofile with recorded test as well)? We would like to take a look at it.
