ONLYOFFICE Docs v7.3 released: enhanced forms, SmartArt, new security settings, Watch Window, and more
From where can i get the document identifier key
Hi I am trying to convert the word doc to pdf using the conversion api. But i cannot find how to get this key value and is it possible to get this key form api by providing the file id.
Hello @shankar
The key value generation is your task as independent integrator. Each request to document server should have unique key value.
Sum it up, you can set any value for ‘key’ parameter in conversion request and it should work.
I am having the same problem what do i use as api url here??
Hello @Molotov
It doesn’t matter how url to the file looks. The main point is Document server availability to get a file from such link. Files storing and management is your task as independent integrator.
I believe this guide will be useful:
https://api.onlyoffice.com/editors/open
