FREEZE PANE BUG - KEEP ON REDIRECTING TO DEFAULT VISIBLE PANE
Do you want to: Report a bug
For feature suggestions, describe the result you would like to achieve in detail: NA
  1. Freeze pane not working beyond visible view
  2. for instance, visible view is column A to column J, when freeze column AB, it will redirected to column A to column J view.
  3. Beyond Column J is not accesible during freeze pane
  4. Link to video provided
    DocumentBuilder version: onlyoffice-documentserver 8.3.3-18
    Installation method: DOCKER
    OS: Ubuntu Server
    Additional information: Access via Synology
    (personal synology)
the synology link is the video link, please click to download/view the .mp4 video
Hello @BPMECH
We will take a closer look at the reported behavior and I will share the feedback.
UPD: I was informed that this is a known bug and there is work in the process. Sorry for the inconvenience.
Hi, thank you for responding, please let me know if anyway I could help.
