I’m considering moving from MSOffice and this is the very first time ever I open Only office to try so as a result, I am not sure if this is a feature missing, a bug, or just that I don’t know how to use the program. I tried googling for some times before asking but results regarding only office are quite sparse so I did not find anything.
Steps:
- Have a table with formulas
- right-click on any table element
- Insert
- New row above/under
Behavior in MSOffice:
- Newly created elements already have their forumlas setup so you just have to fill
Behavior in OnlyOffice
- Newly created elements are just blank elements without any forumla whatsoever
Because I’m french, I’m not sure if I’m using the correct english terms to describe my issue so attached below are a demo of what I’m trying to explain in MSOffice and OnlyOffice using a document I got online. (I cannot/don’t want to share my work/personal documents)
MSOffice : https://imgur.com/a/5Ud7P2Y
OnlyOffice : https://imgur.com/a/s5TqvYt
