The cells in column K and the lines from 66 to 77 contain a formula that sums up all the values in column K.
This causes problems, as another cell (like K77) tries to calculate a value that contains the above-mentioned formula.
In order to get the desired result I need to specify ranges (e.g., K1:K60) instead of the entire K column in cells 66 to 77.
What misled me is that this function returns the correct result in Excel, but not in Onlyoffice.
I don’t know if you could evolve the function in Onlyoffice so that it works like in Excel?
New version of Document Server was released recently, in this version this issue should be fixed. Please update your instance and check situation again.
