Hello
I have onlyoffice installed in a personnal owncloud server on ubuntu server.
I can share onlyoffice file with public link but the public user can not modify the file.
Is it a owncloud configuration or a onlyoffice configuration?
Manythanks
Hello
Manythanks
Hello ewok2.
File sharing feature is relarted to ownCloud settings. When Document server is integrated with a storage (ownCloud in your case), its main goal is file editing.
But I think we have a workaround solution for you. Try to share whole folder with editing rights. In this case, your public users will be able to open files from such folder for editing.
Wonderful Alexandre,
By setting the rw on the directory it works fine.
Thank you very much i!!
