Feature suggestion - Folder upload
I often get timeouts when uploading a whole folder to Docspace, resulting in files missing in the uploaded folder structure. My suggestion for a feature is this. Either allow you to click on the file that said “upload failed” and allow re-try, or allow you to export the file list with the status so you manually can upload the files that failed to upload.
Hello @ahogrelius
Thank you for the suggestion. We will take a closer look at it and I will provide a feedback.
Sorry for the delayed response. I was informed that the suggestion has been registered and there is already work in the progress. Unfortunately, I do not have any exact ETA on that, but I will keep you posted.
