Need dedicated support? Click here
Click here
[FEATURE REQUEST] Option to not jump to next line when hitting Enter
After adding data to a cell, we hit the Enter key, upon which the cursor jumps to the cell right below in the next line.
Please add an option to, after hitting Enter leave the cursor in the same cell.
OS version: macOS 13 Ventura
App version: 7.4.1
Hello @Klaas-Vaak
If I understand your suggestion correctly, by pressing Enter key you want simply leave editing of the cell so the cursor remains on the same cell, is that correct?
Yes, that is correct.
In Windows, Ctrl-Enter does that.
Maybe something similar in MacOS?
Thanks for the tip. In macOS Ctrl-Enter works too. This one is not listed in the keyboard shortcuts. It should be there.
Agreed, we have collected your feedback. I believe we will add description for this shortcut in the one of the future releases.
OK, @Alexandre, when the description has been implemented you can close this issue.
Thanks for you help.
