Hi @nicolas.a.grandin
I don’t often actively seek out ordinal suffixes (I think that’s what they’re called) like “st”, “nd”, etc, but I do use “±” and similar like “½” quite often.
But what I do use is a 3rd party utility called AutoHotKey which I use to gain access to these special characters in any application running on my computer (Win 10). This utility can detect any string typed, and substitute “on the fly”.
For instance, if I type “+//-”, then “±” appears instead. This is achieved using a special instruction in AutoHotKey’s configuration file
I didn’t realise that OnlyOffice does not currently convert “1st” to the superscripted suffix, which shows how often I’ve needed it
But I did get AutoHotKey to do the lifting;
HotIfWinActive "ahk_class ONLYOFFICE"
:*?:0th::0^,th^,
:*?:1st::1^,st^,
:*?:2nd::2^,nd^,
:*?:3rd::3^,rd^,
:*?:4th::4^,th^,
:*?:5th::5^,th^,
:*?:6th::6^,th^,
:*?:7th::7^,th^,
:*?:8th::8^,th^,
:*?:9th::9^,th^,
HotIfWinActive
So when I am typing in OnlyOffice, and I type a number followed by an ordinal suffix, then that suffix is superscripted; that is what the “^,” (representing Ctrl+,) does, ending with the same keyboard control to turn it off again. And the whole block of rules are bound with an instruction that it is only applicable to OnlyOffice.
Via AutoHotKey, I have quick access to a whole library of special characters.
If you are feeling adventurous, and keen to add that functionality, you may wish to investigate this utility too.
These are some of the other mathematics based ones I use as well;
:*?:!x::×
:*?:!ax::𝑥
:*?:!ay::𝑦
:*?:!ax::𝑧
:*?:!\0::Ø
