Excel - Vertical text in Columns get cut
Hi All,
I open an Excel dok in OnlyOffice with Vertical text in Columns. Text get cut on top.
Is there any way to do this so that all text is visible?
Thank you very much for feedback!
Best regards,
Linda
Hello @Linda
Can you specify how this text was rotated and version of Document Server? If possible, please share the file itself so we can check it out.
Hi Constantine,
text was formatted with normal Cell-formatting in Excel.
Document server I have no idea. Suppose this should be ok with any Document Server?
Here is an image because the Forum says that a new user cant upload attachments. Sorry.
It is just an ordinary excel with text in the first row formatted as “on top” (in the cell) and 90 deg rotation.
Many Thanks.
Best regards,
Linda
Hi there,
some more info that I got:
“OnlyOffice Version number: 8.1.1.1”
“Operating System: Docker”
VG,
Linda
Hello @Linda
Your forum level has been increased. Please provide us with a test file, we will check it out.
Hi again,
here is a file you can test.
Example-OnlyOffice-text cut when vertical.xlsx (10.6 KB)
Thank you very much!
Best Regards,
Linda
Thank you. Can you also share how this document is displayed in Docs too?
As I can see, provided document slightly differs from the one on the screenshot. For instance, in cell B4 on the screenshot the value is “Column”, when in the provided document it is “Line”.
Also, I didn’t experience any issues with table being cut off in any way.
