Creating slides, I often change the size of the pictures I include.
Sometimes, I use the handles, but often I use the “size” parameter to set pictures to the same or a given size.
It would be nice from a productivity standpoint to shorten the path to this parameter by putting it (for instance) bellow the rotate options, instead of the current position inside the advance parameters pop-up:
If it is compatible with your usability guidelines, it would be nice.
Thanks.
