Hi
In a lot of apps (MSO, inkscape, LO,…) CTRL W closes the current document.
It would be nice to have the same in OO.
Thanks.
Hello @arcqus
I wanted to inform you that ONLYOFFICE Desktop Editors have a keyboard shortcut for closing documents - CTRL + W.
If you’re interested in learning more keyboard shortcuts for our editors, I recommend checking out our Help Center at https://helpcenter.onlyoffice.com/ONLYOFFICE-Editors/ONLYOFFICE-Document-Editor/HelpfulHints/KeyboardShortcuts.aspx. There, you can find a comprehensive list of keyboard shortcuts that can help you work even more efficiently in our editors.
Let me know if you have any other questions or concerns!
Hi Russel,
Thanks for the link, I will read it.
But… I tested again, wondering if I’m a little mad… And CTRL W is not working on my laptop.
- I don’t use tabs but a separate window for each file.
- I’m on a laptop (inspiron 5425) and when I do CTRL F4 or CTRL fn F4, it stops the music but does not close the document.
Hi again Russel
I did the test on another computer - a desktop this time.
When OO is set to use tabs, CTR W works.
When it is set to use separated windows, it no longer works.
CTRL F4 is not working either.
So, is it a bug ?
Thanks.
Could you please record a video of your screen with the current scenario so that we can investigate the issue? It would be really helpful for us to have a visual representation of the problem.
Thank you!
I’m not sure it’s sufficient to help.
I recorded my screen & added the description of what I do in the opened file.
Hello @arcqus
Thank you very much for providing us with the information. At this time, we are reviewing the situation and we will definitely notify you of any updates.
Hello @arcqus
Thank you for providing us with the necessary information. We were able to reproduce the scenario and have registered the issue under bug number 61387 in our internal tracking system. We apologize for any inconvenience this may have caused and we will notify you as soon as the issue is fixed.
Thank you for your understanding and patience.
