events_onDocumentStateChange not working
I am currently working on implementing “Filling out the form” using React.
(ONLYOFFICE Api Documentation - External access to the document editing)
import { DocumentEditor } from "@onlyoffice/document-editor-react";
import React, { useState } from "react";
function App() {
  var connector = "";
  const [contentControls, setContentControls] = useState([]);
  var onDocumentReady = function () {
    try {
      var docEditor = window.DocEditor.instances["oformEditor"];
      connector = docEditor.createConnector();
      getAllContentControls();
      connector.attachEvent("onChangeContentControl", onChangeContentControl);
    } catch (err) {
      console.error(err);
  const getAllContentControls = () => {
    connector.executeMethod("GetAllContentControls", null, function (data) {
      setTimeout(function () {
        for (let i = 0; i < data.length; i++) {
          connector.executeMethod("GetFormValue", data[i].InternalId, function (value) {
            data[i].Value = value ? value : "";
            if (data.length - 1 === i) {
              setContentControls(data);
      }, 3000 * 10);
  const onChangeContentControl = (data) => {
    console.log("check onChangeContentControl");
    window.Asc.plugin.executeMethod("GetFormsByTag", data.Tag, function (data) {
      console.log("check GetFormsByTag");
      for (var i = 0; i < data.length; i++) {
        if (data[i].InternalId != null) {
          connector.executeMethod("SelectContentControl", [data[i].InternalId]);
          break;
    connector.executeMethod("GetFormValue", data.DocumentId, data.FormId, function (value) {
      data.Value = value ? value : "";
  const onDocumentStateChange = (e) => {
    console.log("server connect ", e.data);
  return (
    <div className="App" >
      <div>
        <DocumentEditor
          id="oformEditor"
          documentServerUrl="http://192.168.0.229/"
          config={{
            document: {
              fileType: "oform",
              key: "oform" + Math.random(),
              title: "test.oform",
              url: "https://d2nlctn12v279m.cloudfront.net/assets/docs/samples/demo.oform"
            documentType: "word",
          height="800px"
          events_onDocumentReady={onDocumentReady}
          events_onDocumentStateChange={onDocumentStateChange}
          events_onChangeContentControl={onChangeContentControl}
      </div>
    </div>
export default App;
Here is my current code, and initially, I confirmed that if there were any changes, the events_onChangeContentControl function was functioning. However, one day, this event stopped working.
I don’t think it’s a connection issue with the document server because I have confirmed that events_onDocumentStateChange is still functioning.
Document Server version: 7.3.3.49
Installation method: Docker
OS: ubuntu 22.04.2 LTS
[reference document]
https://api.onlyoffice.com/editors/interactingoutside/fillingform
https://api.onlyoffice.com/editors/react
https://github.com/ONLYOFFICE/document-editor-react code
I found that onlyoffice was updated to version 7.4.0.163
When it worked after the update, I confirmed that events_onDocumentStateChange was working!
Hello @yejin
I’m a little bit confused. Has the issue been resolved after update to v7.4? Please clarify the current situation.
