I’ve tried to make a document to PDF conversion using this script:
builder.OpenFile("Sample.docx");
builder.SaveFile("pdf", "Sample.pdf");
builder.CloseFile();
But this error is thrown and I’m not sure which info is missing:
TypeError: Cannot read property 'length' of undefined
at Object.a.AscCommon.yK.decode.a.AscCommon.yK.decode (<anonymous>:12281:172)
at e (<anonymous>:12196:526)
at n.On (<anonymous>:12216:377)
at Object.On (<anonymous>:12221:177)
at g.e.T4c (<anonymous>:10608:404)
at g.T4c (<anonymous>:10946:79)
at <anonymous>:10553:418
at ra (<anonymous>:10027:381)
at Object.a.AscCommon.WFg (<anonymous>:10195:405)
at g.e.qla (<anonymous>:10553:381)
# Fatal error in v8::ToLocalChecked
# Empty MaybeLocal.
Hello @Monkiki
Please specify how and where do you use this script and where do you see this error?
Executed from Linux command line:
$ documentbuilder sample.docbuilder
Sorry for the late response.
Please provide the version of Document Builder that you are using.
If possible, also share a document that you have troubles with. You can upload it to any cloud storage and share an external link.
Document Builder version:
- v7.4.0.166
- sdk version: 7.4.0 (build:166)
The document can be downloaded from https://transfer.sh/SkxehPQL2V/Sample.docx but this happens with any other.
Thank you. Unfortunately, I wasn’t able to reproduce the issue.
Some additional information needed:
- do you execute the command with
sudo
- what OS are you running?
- did you install the dependencies as per guide?
Using Ubuntu 23.04
I tried with sudo and worked. After than, with a regular user also worked.
I don’t understand why
Indeed, this is quite strange. Mind me asking if it is working correctly right now?
Yes, it’s working right now. It’s quite odd…
