Error while moving files/folders inside WebDAV-connected storage
Hello! Is there any possibility to move files/folders inside a WebDAV-connected storage on the portal? I’ve got “Error while moving” every time I try, and it’s already a second installation with the same behaviour. Connecting to WebDAV itself by any windows client and moving files/folders through it goes fine, moving works, WebDAV server ok (user, permissions etc.).
Do you want to: Report a bug / Ask a how-to question
Document Server version: 7.2.2.56
Type of installation of the Document Server: docker
OS: Windows 10
Browser version: Google Chrome 109.0.5414.120
Hello @Unicron
What WebDAV storage is used?
Also, please provide information about versions of the components of your portal. Open Control Panel go to Update tab and make a screenshot of it.
Hi, Constantine
WebDAV IIS-based (WindowsServer 2019, IIS 10.0.17763.1)
Control Panel version is 3.1.1.467
Community Server version is 12.1.0.1760
and, as I mentioned above,
Document Server version is 7.2.2.56
Second installation versions:
WebDAV IIS-based (WindowsServer 2012R2, IIS 8.5.9600.16384)
Control Panel version is 3.0.2.395
Community Server version is 11.0.0.1458
Document Server version is 6.0.0.105
Thanks. We will check the situation.
I will update this thread once any news come up.
