i was trying to intergerate the onlyoffice using docker so error faced is errorCode : -20
errorDescription : "The document security token is not correctly formed. Please contact your Document server administrator "
This issue is probably related to the malformed token. The token value needs to be generated according to the following steps:
In the local.json configuration file (located at /etc/onlyoffice/documentserver, inside the container for Docker), find:
