Error OnlyOffice Update on 8.2.2
I am using the ARM version of OnlyOffice 8.2.2, and I encountered the following issue during the service call:
  • Cannot GET /8.2.1/-468XXXX/web-apps/apps/documenteditor/main/index_loader.html
    Document Server version:
    Type of installation of the Document Server (docker, deb/rpm, exe, please point us to the installation guide that you used as well):
    OS:
    Browser version:
    Additional information:
    Any relevant details about the situation. If you’ve modified configuration files or are using a proxy server that might affect the situation, please mention it. You can also attach images and videofile to the post (or to place them to external storage)
Please clarify, how do you reproduce the above-mentioned issue? It can be seen that there is 8.2.1 version number in the service call although you mentioned that you were using 8.2.2 version.
Also, please provide Document Server logs (/var/log/onlyoffice/documentserver)
