Error message when refreshing a dynamic array
Onlyoffice-desktopeditors : version deb 8.3.2 - Ubuntu 24.10
Hi,
After reloading a spreadsheet containing a dynamic array and trying to refresh it ( with alt-F5 or ‘refresh’ button ) , an error message occurs :
‘Overflow of the dynamic array cannot override another array’.
But, the dynamic array is alone in its sheet and refreshing is not done.
If the dynamic array is recreated, refreshing is possible again, until the file is closed and reopened.
With version deb 8.3.0, it’s OK.
Hello @HDubail,
Please provide the original file with which the issue is reproduced
Compta.xlsx (80.4 KB)
The dynamic array is in tne ‘Stats’ sheet.
Hi,
I investigate further : the issue occurs with any new dynamic array created with version 8.3.2.
I join a small file : you can easyly reproduce the issue by selecting a cell in the dynamic array and refreshing it with alt-F5.
Livre1.xlsx (11.8 KB)
Hello @HDubail,
Thank you for the provided info, we are looking into the issue
Did you get any answer from the technical support team about my issue ?
Will it be considered as a bug and fixed in a next release ?
Same error here after upgradnig to 8.3.2
The spreadsheet is a one I’ve created like 1 year ago now.
Hello, the issue is related to a bug, we have added your requests to it, we will do our best to fix it
