Need dedicated support? Click here
Click here
Error download
Hi, I’m trying to set up Nextcloud integration, but after entering my address and password, endless downloads.
What the error looks like:
docker logs onlyoffice-documentserver
[2023-09-06T08:22:42.530] [ERROR] [localhost] [conv_290337298_jpeg] [userId] nodeJS - error downloadFile:url=https://test.ddns.net/apps/onlyoffice/download?doc=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJhY3Rpb24iOiJkb3dubG9hZCIsImZpbGVJZCI6NjY1MSwidXNlcklkIjoiQWRtaW4ifQ.Tt6FJ9rar-gM7cxBSf_TibE5dKFBV8XWMdCvWnw6Zw4;attempt=1;code:ETIMEDOUT;connect:undefined Error: Error: whole request cycle timeout
    at raiseError (/snapshot/server/build/server/Common/sources/utils.js)
    at Timeout._onTimeout (/snapshot/server/build/server/Common/sources/utils.js)
    at listOnTimeout (internal/timers.js:557:17)
    at processTimers (internal/timers.js:500:7)
My configuration:
Document server ver. : 7.4
Nextcloud ver: 27.0.2
config.php
<?php
$CONFIG = array (
  'htaccess.RewriteBase' => '/',
  'memcache.local' => '\\OC\\Memcache\\APCu',
  'apps_paths' =>
  array (
    0 =>
    array (
      'path' => '/var/www/html/apps',
      'url' => '/apps',
      'writable' => false,
    1 =>
    array (
      'path' => '/var/www/html/custom_apps',
      'url' => '/custom_apps',
      'writable' => true,
  'memcache.distributed' => '\\OC\\Memcache\\Redis',
  'memcache.locking' => '\\OC\\Memcache\\Redis',
  'redis' =>
  array (
    'host' => 'redis',
    'password' => '',
    'port' => 6379,
  'instanceid' => 'ocwz6mhjmht2',
  'passwordsalt' => 'VRXU1Xt1AHAZIrtnE2neknAbDUxSx0',
  'secret' => 'MxU1MT9BGsZwm+r+ETW4Jx5HWeI8dtyjOAOJSAOKAlRIgcil',
  'trusted_domains' =>
  array (
    0 => 'test.ddns.net',
    1 => '192.168.0.114',
    2 => '192.168.0.113',
    3 => '172.28.0.4',
  'onlyoffice' =>
  array (
    'verify_peer_off' => true,
  'trusted_proxies' => '172.29.0.2',
  'datadirectory' => '/var/www/html/data',
  'dbtype' => 'pgsql',
  'version' => '27.0.2.1',
  'overwrite.cli.url' => 'http://test.ddns.net',
  'dbname' => 'nextcloud',
  'overwriteprotocol' => 'https',
  'dbhost' => 'db',
  'dbport' => '',
  'dbtableprefix' => 'oc_',
  'dbuser' => 'oc_admin',
  'dbpassword' => 'NXswJdKgzsOZcPLA2CNXMF7WY8Fu3Y',
  'installed' => true,
/etc/onlyoffice/documentserver/default.json
  "services": {
    "CoAuthoring": {
      "request-filtering-agent": {
        "allowPrivateIPAddress": true,
        "allowMetaIPAddress": true
                                "gzip": true,
                                "rejectUnauthorized": false
docker-compose.yml
version: '2'
services:
  onlyoffice-documentserver:
    image: onlyoffice/documentserver:latest
    container_name: onlyoffice-documentserver
    depends_on:
      - onlyoffice-postgresql
      - onlyoffice-rabbitmq
    environment:
      # - USE_UNAUTHORIZED_STORAGE=true
      - DB_TYPE=postgres
      - DB_HOST=onlyoffice-postgresql
      - DB_PORT=5432
      - DB_NAME=onlyoffice
      - DB_USER=onlyoffice
      - AMQP_URI=amqp://guest:guest@onlyoffice-rabbitmq
      - JWT_ENABLED=true
      - JWT_SECRET=secret
      - JWT_HEADER=AuthorizationJwt
    ports:
      - '443:443'
      - '80:80'
    stdin_open: true
    restart: always
    stop_grace_period: 60s
    volumes:
       - onlyoffice_data:/var/www/onlyoffice/Data
       - onlyoffice_log:/var/log/onlyoffice
       - onlyoffice_cache:/var/lib/onlyoffice/documentserver/App_Data/cache/files
       - /var/www/onlyoffice/documentserver-example/public/files
       - onlyoffice_fonts:/usr/share/fonts
  onlyoffice-rabbitmq:
    container_name: onlyoffice-rabbitmq
    image: rabbitmq
    restart: always
    expose:
      - '5672'
  onlyoffice-postgresql:
    container_name: onlyoffice-postgresql
    image: postgres:9.5
    environment:
      - POSTGRES_DB=onlyoffice
      - POSTGRES_USER=onlyoffice
      - POSTGRES_HOST_AUTH_METHOD=trust
    restart: always
    expose:
      - '5433'
    volumes:
      - postgresql_data:/var/lib/postgresql
volumes:
  postgresql_data:
  onlyoffice_data:
  onlyoffice_log:
  onlyoffice_cache:
  onlyoffice_fonts:
I also use nginx reverse proxy for Nextcloud
Hello @TwoTwoSep
Since there is proxy used, please refer to the recommended configs for various proxy services and compare your config with one of these:
https://helpcenter.onlyoffice.com/installation/docs-community-proxy.aspx
I’d also recommend checking integrated test example for editing of documents. Simply navigate to the Welcome Page of Document Server via its address in browser, follow instruction on the page to enable test example in the first place and then tap on GO TO TEST EXAMPLE button to open example to check situation there.
Hello, thank you for your reply. I have checked the Onlyoffice example works, the files are edited and there are no errors. I will try to set up a proxy.
