Error at Installation on Ubuntu 24.04
I use:
  • Ubuntu 24.04
  • DesktopVersion
  • AMD 64
  • as VM on Proxmox
  • the hardware-requirements are enough
I have got your last Installation-Skript today
I want to install it without docker
When i try to install it i get the following output:
sudo bash workspace-enterprise-install.sh
Select 'Y' to install ONLYOFFICE using Docker (recommended). Select 'N' to install it using RPM/DEB packages.
Please note, that in case you select RPM/DEB installation, 'HTTPS' and 'Update' sections will be absent from the Control Panel.
You will also need to manually install Mail Server and connect it to your ONLYOFFICE installation.
See instructions in our Help Center: http://helpcenter.onlyoffice.com/server/docker/mail/connect-mail-server-to-community-server-via-portal-settings.aspx
Install with Docker [Y/N/C]? n
OK:1 http://download.onlyoffice.com/repo/debian squeeze InRelease
OK:2 http://de.archive.ubuntu.com/ubuntu noble InRelease
OK:3 http://de.archive.ubuntu.com/ubuntu noble-updates InRelease
OK:4 http://security.ubuntu.com/ubuntu noble-security InRelease
OK:5 http://de.archive.ubuntu.com/ubuntu noble-backports InRelease
OK:6 https://d2nlctn12v279m.cloudfront.net/repo/mono/ubuntu xenial InRelease
OK:7 https://artifacts.elastic.co/packages/7.x/apt stable InRelease
OK:8 https://packages.microsoft.com/ubuntu/24.04/prod noble InRelease
OK:9 https://download.mono-project.com/repo/ubuntu vs-bionic InRelease
Ign:10 https://download.mono-project.com/repo/ubuntu stable-noble/snapshots/6.8.0.123 InRelease
OK:11 https://packages.redis.io/deb noble InRelease
Fehl:12 https://download.mono-project.com/repo/ubuntu stable-noble/snapshots/6.8.0.123 Release
  404  The specified blob does not exist. [IP: 13.107.246.45 443]
Paketlisten werden gelesen… Fertig
E: Das Depot »https://download.mono-project.com/repo/ubuntu stable-noble/snapshots/6.8.0.123 Release« enthält keine Release-Datei.
N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
W: https://download.mono-project.com/repo/ubuntu/dists/vs-bionic/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
Hello @haglo
Sorry for the late reply.
We are checking the situation, I will contact you as soon as possible.
Dear @haglo
Please accept our apologies for the current situation. We have found a bug on the Ubuntu 24.04 in the scenario of installation. It will be fixed in the next version of Community server (v.12.7). The workaround solution is using an earlier version of Ubuntu (v.22.0.4) at the moment.
