Error 255 when saving to PDF
Hello!
I have a simple document builder code:
builder.CreateFile("docx");
oParagraph.AddText("This sample text is saved to the pdf.");
builder.SaveFile("pdf", "testfiles\Save.pdf");
builder.CloseFile();
I run “docbuilder.exe testpdf.docbuilder”, and error is occured:
error: : save file error (255)
What does it mean? What to do?
I noticed, if i delete the line “oParagraph.AddText(“This sample text is saved to the pdf.”);”, no error is occured, but I get an empty pdf document :slight_smile:
DocumentBuilder version: 7.4
Installation method: msi
OS: Microsoft Windows 10 version 10.0 (Build 14393)
Hello @Anton
Please note that symbols \ / : * ? " < > | cannot be used in the file name.
Try running the script with this line like that, for example:
builder.SaveFile("pdf", "testfiles_Save.pdf");
Hello, @Constantine
If I cannot use the symbols / \, how can I change the catalog where the file will be saved in?
I want the file to be saved in the catalog C:\ONLYOFFICE\DocumentBuilder\testfiles, how can i do this?
What I did:
I specified the file path in the method SaveFile, like this: builder.SaveFile("pdf", "testfiles\Save.pdf");
I ran docbuilder.exe via cmd in the catalog C:\ONLYOFFICE\DocumentBuilder
Could you please explain me this situation, i’m a little confused :slight_smile:
P.S. I try runnig with this line builder.SaveFile("pdf", "testfiles_Save.pdf"); and get the same error: error: : save file error (255)
You must use either an absolute or a relative path to the destination folder. For example:
builder.SaveFile("pdf", "C:\Program Files\ONLYOFFICE\DocumentBuilder\testfiles\Save.pdf");
builder.SaveFile("pdf", "./testfiles/Save.pdf");
Please try running Command Line from Administrator and check if it makes any difference.
This helps me!!
Thank you a lot! :slight_smile:
I’m glad to hear that it works!
