Error 1603 while updating workspace
Do you want to: Report a bug
For bug reports, provide the steps to reproduce and if possible a minimal demo of the problem: Updating version of workspace ending with error.
Community Server/Control Panel version: v12.5.1226 / v 3.5.42
Type of installation of Workspace (docker, deb/rpm, exe): exe
OS: Windows server 2016
Browser version: latest goole chrome
End of error log:
Property(S): SourcedirProduct = {0A1D8686-BBE1-48EF-BA6A-D3616E630B43}
Property(S): AI_CHAINER_CMD_LINE = {0A1D8686-BBE1-48EF-BA6A-D3616E630B43}5IC:\Users\pitersky.im\AppData\Local\Temp\ControlPanel_Win-install.latest.msiAPPDIR=“C:\Program Files (x86)\Ascensio System SIA\ControlPanel” API_SYSTEM_PORT=“8081” CONTROL_PANEL_PORT=“8082” MYSQLODBCDRIVER=“MySQL ODBC 8.0 Unicode Driver” SERVER_PROP=localhost DATABASE_PROP=onlyoffice USERNAME_PROP=root PASSWORD_PROP=onlyoffice PORT_PROP=3306C:\Users\pitersky.im\AppData\Local\Temp\CHAINERS_LOG\ControlPanel_Win-install.v22.11.743.logNVIC:\Users\pitersky.im\AppData\Local\Temp\CommunityServer_Win-install.latest.msiAPPDIR=“C:\Program Files (x86)\Ascensio System SIA\CommunityServer” INSTALLATION_TYPE=Workspace DOCUMENT_SERVER_INSTALLED=“TRUE” DOCUMENT_SERVER_PORT=“8083” JWT_ENABLED=“true” JWT_SECRET=“gJVYxHYo0v6ut4JUzRsB7Bhr03NmXj” JWT_HEADER=“AuthorizationJWT” API_SYSTEM_PORT=“8081” CONTROL_PANEL_PORT=“8082” SSO_AUTH_PORT=9834 MYSQLODBCDRIVER=“MySQL ODBC 8.0 Unicode Driver” SERVER_PROP=localhost DATABASE_PROP=onlyoffice USERNAME_PROP=root PASSWORD_PROP=onlyoffice PORT_PROP=3306 ELASTICSEARCH_SCHEME=http ELASTICSEARCH_HOST=localhost ELASTICSEARCH_PORT=9200 C:\Users\pitersky.im\AppData\Local\Temp\CHAINERS_LOG\CommunityServer_Win-install.v22.11.743.logNV8576Chainer
Property(S): AI_MSI_CHAINER_CONDITION = 1
MSI (s) (78:D0) [13:55:54:921]: MainEngineThread is returning 0
MSI (s) (78:84) [13:55:54:921]: RESTART MANAGER: Session closed.
MSI (c) (60:C0) [13:56:00:602]: Back from server. Return value: 1603
MSI (c) (60:C0) [13:56:00:602]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (60:C0) [13:56:00:602]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is ‘1’.
Action ended 13:56:00: ExecuteAction. Return value 3.
=== Verbose logging stopped: 11.05.2023 13:56:00 ===
MSI (c) (80:B8) [13:54:32:181]: Note: 1: 2205 2: 3: AI_TempFile
MSI (c) (80:B8) [13:54:32:181]: Note: 1: 2228 2: 3: AI_TempFile 4: SELECT Property FROM AI_TempFile
MSI (c) (80:B8) [13:54:32:181]: Note: 1: 2205 2: 3: AI_XmlLocator
MSI (c) (80:B8) [13:54:32:181]: Note: 1: 2228 2: 3: AI_XmlLocator 4: SELECT Property FROM AI_XmlLocator
MSI (c) (80:B8) [13:56:00:618]: Doing action: FatalError
Action start 13:56:00: FatalError.
Action ended 13:56:08: FatalError. Return value 1.
MSI (c) (80:B8) [13:56:08:561]: Doing action: AI_SHOW_LOG
Action start 13:56:08: AI_SHOW_LOG.
MSI (c) (80:3C) [13:56:08:561]: Invoking remote custom action. DLL: C:\Users\pitersky.im\AppData\Local\Temp\MSIBC91.tmp, Entrypoint: LaunchLogFile
Action ended 13:56:08: AI_SHOW_LOG. Return value 1.
MSI (c) (80:B8) [13:56:08:733]: Doing action: FatalError
Action start 13:56:08: FatalError.
MSI (c) (80:B8) [13:56:08:733]: Doing action: AI_CleanPrereq
Action start 13:56:08: AI_CleanPrereq.
MSI (c) (80:88) [13:56:08:733]: Invoking remote custom action. DLL: C:\Users\pitersky.im\AppData\Local\Temp\MSIBD3E.tmp, Entrypoint: CleanPrereq
Action ended 13:56:08: AI_CleanPrereq. Return value 1.
MSI (c) (80:B8) [13:56:08:858]: Doing action: FatalError
Action ended 13:56:08: FatalError. Return value 2.
MSI (c) (80:B8) [13:56:08:858]: Note: 1: 2205 2: 3: Environment
MSI (c) (80:B8) [13:56:08:858]: Note: 1: 2228 2: 3: Environment 4: SELECT Environment,Component_ FROM Environment
MSI (c) (80:B8) [13:56:08:873]: Destroying RemoteAPI object.
MSI (c) (80:F8) [13:56:08:873]: Custom Action Manager thread ending.
=== Verbose logging stopped: 11.05.2023 13:56:08 ===
And when try to install community server this error log:
Property(S): PrimaryVolumeSpaceAvailable = 165228544
Property(S): PrimaryVolumeSpaceRequired = 3211744
Property(S): PrimaryVolumeSpaceRemaining = 162016800
Property(S): ARP_ICON_PATH = C:\Windows\Installer{691B7643-66C5-4FF1-BC93-429BAECBCB8C}\icon.exe
Property(S): PrimaryVolumePath = C:
Property(S): AI_ARP_SIZE = 1587312
Property(S): SOURCEDIR = C:\Users\pitersky.im\AppData\Roaming\Ascensio System SIA\CommunityServer\install
Property(S): SourcedirProduct = {691B7643-66C5-4FF1-BC93-429BAECBCB8C}
Property(S): AI_SERVICE_STATE = Started
Property(S): ELASTIC_SEARCH_PLUGINS_DIR = C:/Program Files (x86)/Ascensio System SIA/CommunityServer/Tools/elasticsearch/plugins/
Property(S): POWERSHELL_EXECUTION_LOG = Downloading https://github.com/BtbN/FFmpeg-Builds/releases/download/latest/ffmpeg-master-latest-win64-gpl.zip
ERROR: The request was aborted: Could not create SSL/TLS secure channel.
MSI (s) (48:1C) [16:49:17:021]: MainEngineThread is returning 1603
MSI (s) (48:94) [16:49:17:021]: RESTART MANAGER: Session closed.
MSI (s) (48:94) [16:49:17:021]: No System Restore sequence number for this installation.
MSI (s) (48:94) [16:49:17:037]: User policy value ‘DisableRollback’ is 0
MSI (s) (48:94) [16:49:17:037]: Machine policy value ‘DisableRollback’ is 0
MSI (s) (48:94) [16:49:17:037]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (48:94) [16:49:17:037]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (48:94) [16:49:17:037]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (48:94) [16:49:17:037]: Destroying RemoteAPI object.
MSI (s) (48:D4) [16:49:17:037]: Custom Action Manager thread ending.
MSI (c) (F8:C8) [16:49:17:037]: Back from server. Return value: 1603
MSI (c) (F8:C8) [16:49:17:037]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (F8:C8) [16:49:17:037]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is ‘1’.
Action ended 16:49:17: ExecuteAction. Return value 3.
=== Verbose logging stopped: 11.05.2023 16:49:17 ===
MSI (c) (A8:C0) [16:47:09:583]: PROPERTY CHANGE: Adding AI_MISSING_PREREQS property. Its value is ‘ONLYOFFICE IIS Configure’.
MSI (c) (A8:C0) [16:47:09:583]: PROPERTY CHANGE: Modifying AI_FOUND_PREREQS property. Its current value is ‘.NET Framework 4.8|.NET Runtime 7.0.3 x64|.NET Runtime 7.0.3 x86|ASP.NET Core Runtime 7.0.3 x64|ASP.NET Core Runtime 7.0.3 x86|Visual C++ Redistributable for Visual Studio 2013 x86|Visual C++ Redistributable for Visual Studio 2013 x64|Visual C++ Redistributable for Visual Studio 2015-2019 x86|Visual C++ Redistributable for Visual Studio 2015-2019 x64|MySQL Connector/ODBC 8.0.32 x86|MySQL Installer Community 8.0.32 x86|MySQL Installer Community 8.0.32 x64 Runner|Node.js v12.18.0 x64|SharePoint Server 2013 Client Components SDK x64|Python 3.7.2 x64|Redis 5.0.10 x64|Elasticsearch v7.16.3 x64|WinCertes v1.4.2 x64’. Its new value: '.NET Framework 4.8|.NET Runtime 7.0.3 x64|.NET Runtime 7.0.3 x86|ASP.NET Core Runtime 7.0.3 x64|ASP.NET Core Runtime 7.0.3 x86|Visual C++ Redistributable for Visual Studio 2013 x86|Visual C++ Redistributable for Visual Studio 2013 x64|Visual C++ Redistributable for Visual Studio 2015-2019 x86|Visual C++ Redistributable for Visual Studio 2015-2019 x64|MyS
MSI (c) (A8:C0) [16:47:09:583]: Note: 1: 2205 2: 3: AI_TempFile
MSI (c) (A8:C0) [16:47:09:583]: Note: 1: 2228 2: 3: AI_TempFile 4: SELECT Property FROM AI_TempFile
MSI (c) (A8:C0) [16:47:10:036]: Note: 1: 2205 2: 3: AI_ChainedPackage
MSI (c) (A8:C0) [16:47:10:036]: Note: 1: 2228 2: 3: AI_ChainedPackage 4: SELECT ChainedPackage FROM AI_ChainedPackage
MSI (c) (A8:C0) [16:49:17:068]: Doing action: FatalError
Action start 16:49:17: FatalError.
Action ended 16:49:19: FatalError. Return value 1.
MSI (c) (A8:C0) [16:49:19:193]: Doing action: AI_SHOW_LOG
Action start 16:49:19: AI_SHOW_LOG.
MSI (c) (A8:D0) [16:49:19:208]: Invoking remote custom action. DLL: C:\Users\pitersky.im\AppData\Local\Temp\MSIAD7.tmp, Entrypoint: LaunchLogFile
Action ended 16:49:19: AI_SHOW_LOG. Return value 1.
MSI (c) (A8:C0) [16:49:19:318]: Doing action: FatalError
Action start 16:49:19: FatalError.
MSI (c) (A8:C0) [16:49:19:318]: Doing action: AI_CleanPrereq
Action start 16:49:19: AI_CleanPrereq.
MSI (c) (A8:C0) [16:49:19:333]: Invoking remote custom action. DLL: C:\Users\pitersky.im\AppData\Local\Temp\MSIB65.tmp, Entrypoint: CleanPrereq
Action ended 16:49:19: AI_CleanPrereq. Return value 1.
MSI (c) (A8:C0) [16:49:19:458]: Doing action: FatalError
Action ended 16:49:19: FatalError. Return value 2.
MSI (c) (A8:C0) [16:49:19:458]: Note: 1: 2205 2: 3: Environment
MSI (c) (A8:C0) [16:49:19:458]: Note: 1: 2228 2: 3: Environment 4: SELECT Environment,Component_ FROM Environment
MSI (c) (A8:C0) [16:49:19:474]: Destroying RemoteAPI object.
MSI (c) (A8:F8) [16:49:19:474]: Custom Action Manager thread ending.
=== Verbose logging stopped: 11.05.2023 16:49:19 ===
Hello @grinderblade
Please specify how did you update Workspace? If you’ve used a guide, please share it.
Additionally, please specify:
  • What is the current state of Workspace portal?
  • Where did you see all these records?
I download latest installation of modules from control panel and just begin updating. In my case it was Control Panel, XMPP server and Community server. First was Control panel and it was installed without problem. Then was community server and after update it was ending with error. Log in my first post was from installation of community server. I found this string
Error with this was in tls ssl settings for powershell. It help me troubleshooting. I add record in regedit
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft.NETFramework\v2.0.50727]
“SystemDefaultTlsVersions”=dword:00000001
“SchUseStrongCrypto”=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft.NETFramework\v4.0.30319]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NETFramework\v2.0.50727]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NETFramework\v4.0.30319]
Then installation was success but after i have error 500 when i try open site of my Workspace
Please provide logs of Community Server and Control Panel. You can find those in C:\Program Files (x86)\Ascensio System SIA\CommunityServer\Log\ and C:\Program Files (x86)\Ascensio System SIA\ControlPanel\Log\ for analysis. You can upload them as archives and send a link via PM.
Additionally, try to remember from which versions you have tried to update.
Just in test purposes try to restart ONLYOFFICE site in IIS of your Windows Server and check the situation again. Will it make any difference?
Hello @maslov
Please specify on which step does this issue occur? Is it the step with installation of prerequisites or of the main app?
In test purposes you can try emptying temp folder of the installer (the path is C:\Users\<user>\AppData\Local\Temp) and trying to run the installer again.
Please check out logs in Event Viewer > Windows Logs > Applications for the time when installation of Groups was performed or try installing it again to produce new logs and share them with me.
