unfortunately the general keyboard shortcut Alt + = does not work,
because on a German keyboard the = sign must be written via Shift + 0.
I am looking for a way to somehow start an equation with a keyboard shortcut anyway.
Unfortunately I didn’t find anything in the API documentation either. Is there a command for equations or is it possible to realize another keyboard shortcut to call an equation with a macro.
I would be happy if someone has an idea or if someone from the OnlyOffice support team is reading and maybe a possibility will be created in a future version.
Greetings
Matt
OS version: Windows 10 (21H2 19044.2075)
App version: 7.2.0.204 (64-bit)
Hello @mattwill
Please describe the situation. Do you mean that physical German keyboard incorrectly uses Alt+= shortcut in docx files? If it’s possible please reproduce the situation and make a videofile.
Hello Alexandre,
thank you for your answer.
I made a video showing the difference between the English and German keyboard layouts when using the keyboard shortcut.
Video
The same problem was also raised here.
other Forum
I think that the extra shift key is the problem.
Greetings
Matt
Thank you for provided videofile, we are checking the situation
Hello @mattwill
Thank you for pointing us to this situation. We added a bug to internal tracksystem (59330).
We have started working on it.
Hello @Alexandre,
thank you very much for taking care of it so quickly.
I hope for a future version.
Too bad, nothing has changed in over two years.
Hello @mattwill
Please accept our sincere apologies for the length of the situation. We are still working on the reported bug and we will contact you immediately once the fix is released.
