Hi,
we are using the latest version of OnlyOffice Workspace.
We just started using the E-Mail function. The standard fond-type is OpenSans. Is there a way to change the standard fond?
Thanks for your help!
Hi,
Hello @frank
Unfortunately, you can’t change the default font for the letter. However I will consider your message a suggestion and forward it to our developers for further consideration.
Hi @Kate
thanks for your reply - that would be a great feature since many companies have their CI and their Mail-layouts should match that
