Hi Alexandre, yes, I have also restarted the server several times and it does not work. I can’t restart the service anyway, this shows me the terminal (I have a very basic level of Linux, no level in docker) Failed to restart onlyofficeMailAggregator.service: Unit onlyofficeMailAggregator.service not found. The server installation was done with this guide:
https://helpcenter.onlyoffice.com/installation/workspace-install-docker.aspx
and these commands :
wget https://download.onlyoffice.com/install/workspace-install.sh
sudo bash workspace-install.sh -md nube.mydomain.es
Then it’s all automatic, but I didn’t know that I didn’t need OnlyOffice Mail Server to only use IMAP and use OnlyOffice Mail as a module.
I remember also installing the Windows version and not getting the download to work by IMAP, the SMTP service if it works and sends the emails.
As an additional fact, if I connect a GMail account, the download, sending and synchronization works correctly, the Mail module if it works with this provider, why does not my account? My third-party server has SSL certificates, my domain mail supports SSL/TLS, and the OnlyOffice Workspace server also has LEts Encrypt.
Thanks for everything, greetings.
