我们安装8.2.2版本的onlyoffice,将它部署到一台服务器上,并使用apisix进行了请求转发,之前apisix使用的是服务器的80端口,onlyoffice组件可以正常加载,最近更换了apisix的端口,打开文档提示下载失败,Editor.bin未成功加载,我们发现websocket返回回来的消息中关于Editor.bin的请求未拼接端口,导致服务找到文件,请问我们应该如何解决?
We installed the 8.2.2 version of ONLYOFFICE, deployed it to a server, and used APISIX for request forwarding, before APISIX used the 80 port of the server, ONLYOFFICE components can be loaded normally, recently changed the port of APISIX, open the document prompts that the download failed, Editor.bin did not load successfully, we found that the request about the Editor.bin in the message returned by websocket was not spliced to the port, causing the service to find the file, how should we solve it?
Hello @kaka
Unfortunately, we haven’t tested Document Server functionality behind such service. Does it work as a proxy in your case?
Please check out Document Servers’ logs in the directory /var/log/onlyoffice/documentserver and share any error entries with status ERROR
that you may find there.
