Editing problem since Desktop Editors 8.2.0.143 (x64 exe) has been installed
Hi,
with this new version of Desktop Editors the arrow that allows to display the choice list of a cell is not visible anymore. So it is impossible to select an item from the list.
Note : I tried to join an example but as I’m a new user it is impossible.
Thank you for your help.
Hello @Daniel1
I’ve increased your trust level, please share some more details about faced problem, e.g. video, screenshots, document, etc.
Hi,
After updating to version 8.2 ( snap, Ubuntu 24.10), I confirm this problem, which is easy to reproduce : configure a cell with ‘List’ data validation and select this cell.
The arrow in the top right corner of the cell is no more present and it is no more possible to select a value in the list.
Hello @HDubail, @Daniel1
I was informed that this is known issue that will be fixed in next hotfix. I will keep you posted about the update.
