I am having problems when assigning permissions either in folders or files, because when changing from full access to read-only they are appearing outside the main folder and in the subfolder where it belongs, to understand a little more the inconveniences, perform the following diagrams:
At the top of each subfolder and document place the permissions that were assigned.
After assigning permissions for case 3 of the C&M coordinator profile, it appears as follows:
The described scenario is expected behavior if folders owner shares subfolder first. For example, three folders: main folder ‘A’ contains subfolder ‘B’, subfolder ‘B’ contains subfolder ‘C’. With that structure, if a user shares ‘C’ folder first, a user will face described issue (it’s related to portal logic of checking objects rights)
We have added your request to internal tracksystem (internal number - 59630). We have started working on it.
