I am interested in using the API and python to do per-room dumps (backups) in an automated fashion.
I see api-backup definitions.
Is there a way to dump on a room-by-room basis via the API?
Many thanks
Ivan
(WHY? - some room are super busy and some are quiescent)
Hello @ivan
Unfortunately, partial backups are not implemented yet. Technically, you can use following method to get the archive of a room specified in request:
Since room is also considered a folder, you can try sending this request specifying the ID of a room as folderIds
yes please Constantine. Ill be trying API this weekend
ivan
Looking forward to your feedback.
