Hello
It would be great to add in ONLYOFFICE Spreadsheet Editor an option in the creation of drop-down lists form to allow multiple selections. Sometimes the field requires indeed several inputs instead of a unique and exclusive value.
Note : This issue also concerns Excel and can be solved by adding some VBA code (see for instance How to create multi-select drop down list in Excel).
Having the feature natively implemented in Onlyoffice would be great (eg checkbox “multiple selections allowed”) and would avoid JS scripting
Thanks in advance for your feedback !
BW
Benoît
Hello @bdelat
We need some time to check this request. I will update this thread when we have something to share.
Hello @bdelat
We have started working on your suggestion. Thank you for your idea! I will update this thread when we implement it.
Thank you very much for these efforts!
Best
Benoît
