Do you want to: Suggest a feature
I like how after I create a .dotx file and then select it to create a new file from the template it asks me to “Save As…”, however the file type remains as .dotx. Shouldn’t it change to .docx? the only option that appears is “All files” and “.dotx”.
OS version: Windows 11
App version: 7.1.1.57
Document Server: Nextcloud AIO - Docker Install
