Hey! I use the ONLYOFFICE Documentserver via Docker.
As you surely read, there is a big exploit in Log4j.
Does the Documentserver uses any Java / Log4j?
Thanks a lot!
Nils
Thanks a lot!
Nils
I did a docker scan like described in: Apache Log4j 2 CVE-2021-44228 - Docker Blog
It seems like this exploit doesn´t exist in the ONLYOFFICE Documentserver docker but an official statement from ONLYOFFICE would be much appreciated!
Thanks a lot!
Hi everybody,
I am a OnlyOffice Partner but still we don’t have any information yet if OnlyOffice is affected or not. Therefore the following observations are only “MY THOUGHT” and not a official statement of OnlyOffice. I would hope that OnlyOffice will answer this threat and give an official statement.
I checked OnlyOffice Document Server and did not found any hints about log4j. Therefore I think that the document servers are not vulnurable.
BUT the OnlyOffice Community-Server which is part of OnlyOffice Workspace uses log4j bundled with elasticsearch. If you use OnlyOffice Workspace I would recomment to do the following:
I hope this helps
Best regards
Christoph Dyllick from datamate
Hey Christoph!
Thank you for your thoughts.
That sounds already good to me.
But for sure, an official statement would be great!
Hello nilskamm and christophdb.
Document server doesn’t use mentioned library, so it is not affected by the specified vulnerability.
As for the other our products (Workspace), we are checking the situation. I will update this post, when I get any news.
Thank you Alexandre for your fast response!
If we are talking about Workspace, ElasticSearch service uses mentioned library, we are going to update the version of ElasticSearch to the newer one that does not have this vulnerability in the next release that is planned for January 2022.
Workaround solution:
service elasticsearch restart
Hey there,
Edit:
I WAS confused.
I realized there was talk about two things: Document Server and Workspace. I realized that DocServer does not have elasticsearch and that is true, mine also does not have it.
BUT:
Searching for log4j in the Document Server Docker Container brings up some matches:
/etc/onlyoffice/documentserver/log4js
/var/www/onlyoffice/documentserver/server/Common/config/log4js
So the above comment about Doc-Server not having log4j I can not confirm, i guess?
Kind regards,
Martin
Hello Martin.
The folder you specified has nothing to do with the mentioned vulnerability.
Although it has got a similar name to the Java library log4j, it is not the same.
Please check it out: log4js - npm
