Problem: Does document server cache document? When I change the document recieved from document.url, document in editor does not get updated.
Document Server version: 7.4.1
Installation method: Docker
OS: Ubuntu
Browser version: 112.0.5615.165 (Official Build) (64-bit)
Hello!
Here you can check how opening files in Docs editor works - ONLYOFFICE Api Documentation - Opening File
For document opening the document unique identifier (ONLYOFFICE Api Documentation - Config) and url are used. Each document has a unique key, so remember to change it as well.
