Hey folks,
Is there any way to integrate DocuSign with DocSpace?
Thanks in advance!
Hey folks,
Thanks in advance!
Hello @irdi
Unfortunately, DocuSign integration is not available in DocSpace.
Are there any plans on porting it as a feature from OnlyOffice to DocSpace?
Iām not aware of such plans.
As long as OnlyOffice is using it i would propose to port it to DocSpace too. It is a very cool feature and i do not think it is that hard to port since there are other /redistributable/ with exactly the same code which have already been ported to DocSpace.
We will discuss this suggestion internally. I am keeping you posted.
Suggestion was registered, however, no ETA was set yet for this enhancement.
Thank you for your interest. If any news come up in regard this suggestion, I will let you know.
