"Document security key is not correctly formed" error in OnlyOffice, ReactJS
I have to integrate onlyOffice in ReactJS.
OnlyOffice is running on docker and accessible on localhost
Showing this error while opening editor in react app:
“Document security key is not correctly formed. Please contact your document server administrator”
React component:
import React, { useRef } from 'react';
import { DocumentEditor } from "@onlyoffice/document-editor-react";
var onDocumentReady = function (event) {
    console.log("Document is loaded");
var onLoadComponentError = function (errorCode, errorDescription) {
    switch(errorCode) {
        case -1: // Unknown error loading component
            console.log(errorDescription);
            break;
        case -2: // Error load DocsAPI from http://documentserver/
            break;
        case -3: // DocsAPI is not defined
            break;
const formUrl = `${process.env.PUBLIC_URL}/sample4.docx`;
const OnlyOffice = () => {
    return (
            <DocumentEditor
                id="docxEditor"
                documentServerUrl="http://localhost"
                config={{
                    "document": {
                        "fileType": "docx",
                        "title": "Example Document Title.docx",
                        "url": formUrl
                    "documentType": "word",
                    "editorConfig": {
                        "callbackUrl": "https://example.com/url-to-callback.ashx"
                events_onDocumentReady={onDocumentReady}
                onLoadComponentError={onLoadComponentError}
export default OnlyOffice
Hi @harshilsharma,
You need to add token to the editor initialization token when JWT is enabled in Document Server.
If you don’t need JWT, re-deploy the Document Server container and set the JWT_ENABLED variable to false.
docker run -i -t -d -p 80:80 --restart=always -e JWT_ENABLED=false onlyoffice/documentserver
Hi,
When I run this without JWT token than it is not even working on localhost, showing this error “Download Failed”
But if I enable the JWT than it work on localhost but not in reactJS app.
Can you tell me where I have to put the JWT_SECRET in my reactJs app if I want to do by enabling the JWT SECRET ?
As I mentioned earlier, you need to add a token to the editor initialization config as described here:
Editor initialization config is adjusted in App.js file
config={{
                    "document": {
                        "fileType": "docx",
                        "key": "Khirz6zTPdfd7",
                        "url": "https://example.com/url-to-example-document.docx"
                    "editorConfig": {
Also we have noticed that you sent the same request to support@onlyoffice.com. Please do not duplicate the requests.
I tried with JWT_ENABLED=false,
It showing the editor but not able do anything.
showing error:
<div className='h-screen'>
            <DocumentEditor
                height="700"
                id="docxEditor"
                config={{
                    "document": {
                        "fileType": "docx",
                        "url": `http://localhost:3001/sample4.docx`,
                    "editorConfig": {
                        "callbackUrl": "http://localhost:8002/track",
        </div>
(The document.url string is correct)
Document Server does not allow localhost or internal IP addresses by default. Please use this solution: When I call Conversion API,the editor seems to be blocked - #7 by Carl
