Document editor stuck on skeletons with no error
Hello, I’m installing DocSpace from the source code as part of my ongoing quest to sharpen my DevOps skills.
It all went pretty smooth so far using my “patented” trial and error strategy.
I’m writing this because I got stuck. All the services are running and there is no error in the log files.
documentserver-example works and I can edit documents but when I open a document from my personal room the editor is stuck at loading skeletons with no error.
I am sure it is only a configuration issue but I can’t see it.
the only difference I can see is that in the in the working editor I have a request two websocket connections and in the editor that is not working I have only one
thank you!
With a little bit of luck I managed to figure out that request made to /doceditor were missing the Content-Security-Policy headers
Everything works well now … i hope :slight_smile:
Hello @dsl400
Glad to know that the issue is solved. I will close this topic, feel free to create new one in case any other issue occurs.
