Document Editor Method in React
According to: Methods, " After initializing document editor you will get the object that can be used to call the methods.". How to get this method if i use React?
I have read React and it never manually initialize document editor.
My component code:
export default function OnlyofficeDoc() {
  return (
    <div className="w-screen h-screen">
      <DocumentEditor
        id="docxEditor"
        documentServerUrl="http://localhost:80"
        config={document.data}
        events_onDocumentReady={onDocumentReady}
        onLoadComponentError={onLoadComponentError}
        events_onRequestRename={onRequestRename}
        events_onMetaChange={onMetaChange}
        events_onRequestHistory={onRequestHistory}
    </div>
I use latest ONLYOFFICE Docs Community Edition for Docker version on local server
Hello @abi
You need to define methods prior to the initialization of editor. Second provided link in step 4 has simple example that demonstrates how to:
function onDocumentReady(event) {
  console.log("Document is loaded")
function onLoadComponentError(errorCode, errorDescription) {
  ... // your code
export default function App() {
  return (
    <DocumentEditor
      id="docxEditor"
      documentServerUrl="http://documentserver/"
      config={config}
Once editor is initialized, you can rely on necessary methods.
