大家好,我想请教下如下几个问题。
主机环境:虚拟机
主机操作系统:ubuntu server 24.02 lts
网络环境:使用代理访问互联网
部署方式:非docker环境
描述:
之前我安装的docspace community版本为8.2.2。我看到changelog上提示已经有新版本。因此我参照doc的updating方法执行bash docspace-install.sh -u true,但是没有成功。
执行过程中
出现dpkg错误,然后我做了一些处理
但是我reboot后,无法出现login界面,检查
systemctl status redis rabbitmq-server mysql openresty nginx
root@ubunturoot:/home/ubunturoot# systemctl status redis rabbitmq-server mysql openresty nginx
● redis-server.service - Advanced key-value store
Loaded: loaded (/usr/lib/systemd/system/redis-server.service; enabled; preset: enabled)
Active: active (running) since Sat 2025-04-12 00:39:41 UTC; 36min ago
Docs: http://redis.io/documentation,
man:redis-server(1)
Main PID: 924 (redis-server)
Status: "Ready to accept connections"
Tasks: 6 (limit: 19101)
Memory: 7.6M (peak: 8.4M)
CPU: 13.641s
CGroup: /system.slice/redis-server.service
└─924 "/usr/bin/redis-server 127.0.0.1:6379"
Apr 12 00:39:40 ubunturoot systemd[1]: Starting redis-server.service - Advanced key-value store...
Apr 12 00:39:41 ubunturoot systemd[1]: Started redis-server.service - Advanced key-value store.
● rabbitmq-server.service - RabbitMQ Messaging Server
Loaded: loaded (/usr/lib/systemd/system/rabbitmq-server.service; enabled; preset: enabled)
Active: active (running) since Sat 2025-04-12 00:40:19 UTC; 35min ago
Main PID: 923 (beam.smp)
Tasks: 52 (limit: 19101)
Memory: 151.5M (peak: 190.4M)
CPU: 1min 2.471s
CGroup: /system.slice/rabbitmq-server.service
├─ 923 /usr/lib/erlang/erts-13.2.2.5/bin/beam.smp -W w -MBas ageffcbf -MHas ageffcbf -MBlmbcs 512 -MHlmbcs 512 -MMmcs 30 -pc unicode -P 1048576 -t 5000000 -stbt db -zdbbl 128000 -sbwt none -sbwtdcpu none -sbwtdio none -->
├─1065 erl_child_setup 65536
├─1503 /usr/lib/erlang/erts-13.2.2.5/bin/inet_gethost 4
├─1504 /usr/lib/erlang/erts-13.2.2.5/bin/inet_gethost 4
└─2020 /bin/sh -s rabbit_disk_monitor
Apr 12 00:39:40 ubunturoot systemd[1]: Starting rabbitmq-server.service - RabbitMQ Messaging Server...
Apr 12 00:40:19 ubunturoot systemd[1]: Started rabbitmq-server.service - RabbitMQ Messaging Server.
● mysql.service - MySQL Community Server
Loaded: loaded (/usr/lib/systemd/system/mysql.service; enabled; preset: enabled)
Active: active (running) since Sat 2025-04-12 00:39:57 UTC; 36min ago
Docs: man:mysqld(8)
http://dev.mysql.com/doc/refman/en/using-systemd.html
Process: 914 ExecStartPre=/usr/share/mysql-8.4/mysql-systemd-start pre (code=exited, status=0/SUCCESS)
Main PID: 1043 (mysqld)
Status: "Server is operational"
Tasks: 58 (limit: 19101)
Memory: 496.3M (peak: 497.0M)
CPU: 23.998s
CGroup: /system.slice/mysql.service
└─1043 /usr/sbin/mysqld
Apr 12 00:39:40 ubunturoot systemd[1]: Starting mysql.service - MySQL Community Server...
Apr 12 00:39:57 ubunturoot systemd[1]: Started mysql.service - MySQL Community Server.
● openresty.service - The OpenResty Application Platform
Loaded: loaded (/usr/lib/systemd/system/openresty.service; enabled; preset: enabled)
Active: active (running) since Sat 2025-04-12 00:39:44 UTC; 36min ago
Process: 918 ExecStartPre=/usr/local/openresty/nginx/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 1121 ExecStart=/usr/local/openresty/nginx/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 1172 ExecStartPost=/bin/sleep 1 (code=exited, status=0/SUCCESS)
Main PID: 1155 (nginx)
Tasks: 17 (limit: 19101)
Memory: 25.9M (peak: 29.7M)
CPU: 2.802s
CGroup: /system.slice/openresty.service
├─1155 "nginx: master process /usr/local/openresty/nginx/sbin/nginx -g daemon on; master_process on;"
├─1156 "nginx: worker process"
├─1157 "nginx: worker process"
├─1158 "nginx: worker process"
├─1159 "nginx: worker process"
├─1160 "nginx: worker process"
├─1161 "nginx: worker process"
├─1162 "nginx: worker process"
├─1163 "nginx: worker process"
├─1164 "nginx: worker process"
├─1165 "nginx: worker process"
├─1166 "nginx: worker process"
├─1167 "nginx: worker process"
├─1168 "nginx: worker process"
├─1169 "nginx: worker process"
├─1170 "nginx: worker process"
└─1171 "nginx: worker process"
Apr 12 00:39:40 ubunturoot systemd[1]: Starting openresty.service - The OpenResty Application Platform...
Apr 12 00:39:44 ubunturoot systemd[1]: Started openresty.service - The OpenResty Application Platform.
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/usr/lib/systemd/system/nginx.service; enabled; preset: enabled)
Active: active (running) since Sat 2025-04-12 00:39:47 UTC; 36min ago
Docs: man:nginx(8)
Process: 917 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 1313 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Main PID: 1314 (nginx)
Memory: 38.3M (peak: 39.7M)
CPU: 298ms
CGroup: /system.slice/nginx.service
├─1314 "nginx: master process /usr/sbin/nginx -g daemon on; master_process on;"
├─1315 "nginx: worker process"
├─1316 "nginx: worker process"
├─1317 "nginx: worker process"
├─1318 "nginx: worker process"
├─1320 "nginx: worker process"
├─1321 "nginx: worker process"
├─1322 "nginx: worker process"
├─1323 "nginx: worker process"
├─1324 "nginx: worker process"
├─1325 "nginx: worker process"
├─1326 "nginx: worker process"
├─1327 "nginx: worker process"
├─1328 "nginx: worker process"
├─1329 "nginx: worker process"
├─1330 "nginx: worker process"
└─1331 "nginx: worker process"
Apr 12 00:39:40 ubunturoot systemd[1]: Starting nginx.service - A high performance web server and a reverse proxy server...
Apr 12 00:39:47 ubunturoot nginx[917]: 2025/04/12 00:39:40 [info] 917#917: Using 116KiB of shared memory for nchan in /etc/nginx/nginx.conf:61
Apr 12 00:39:47 ubunturoot nginx[917]: 2025/04/12 00:39:40 [info] 917#917: Using 131072KiB of shared memory for nchan in /etc/nginx/nginx.conf:61
Apr 12 00:39:47 ubunturoot systemd[1]: Started nginx.service - A high performance web server and a reverse proxy server.
lines 64-115/115 (END)
检查systemctl | grep docspace,多个service未正常启动。
求助:
1、docspace community的updating是不是不能用bash docspace-install.sh -u true?
2、对于现在,我该如何处理?
3、因为数据我之前都没有备份过 ,如果需要我rebuild docspace community,我现在该如何导出数据?
非常感谢!!!
