DocSpace version: 2.6
Type of installation of the DocSpace (docker, deb/rpm, exe, please point us to the installation guide that you used as well):
OS: docker centos8
Browser version: chrome103
Additional information:安装成功之后,chrome打开,提示升级chrome浏览器
Any relevant details about the situation. If you’ve modified configuration files or are using a proxy server that might affect the situation, please mention it. You can also attach images and videofile to the post (or to place them to external storage)
我这边安装的docspace社区版2.6版本,想咨询下这个版本兼容的浏览器有哪些?thanks
您好,
DocSpace与浏览器的最新版本和之前的两个版本兼容(通常我们对最后三个版本进行测试), Chrome 的最新版本是 128
