DocSpace not running after install
I installed DocSpace on ProxMox Linux Container (LCX) using the packages option and not Docker for reasons that Docker doesn’t work well inside LCX.
Accessing the http://192.168.2.149:8083/ seems to work fine, I can create/upload documents, and view and edit them.
The problem is that DocSpace does not seem to run, and accessing http://192.168.2.149 doesn’t work what it looks like is that no Docspace services are running at all.
root@workspace:~# systemctl | grep docspace
What are the approaches to figure out why DocSpace is not running and what are the possible workaround?
Hello @kerbymart
First of all, please let me know if following topic is still a case:
Not quite following what runs there. Can you elaborate?
Also please let me know which guide did you use to install DocSpace in the first place and if you faced any errors during the installation.
Hi, I used this guide:
https://helpcenter.onlyoffice.com/installation/docspace-community-install-script.aspx
Thanks. Please respond to this:
Basically, where are you creating documents in this reference?
