OnlyOffice Docs Version: 8.0.1.31
NextCloud Hub 8 (29.0.0)
Linux Server: Ubuntu 22.04
Installed OnlyOffice using apt mentioned in the following guide:
Guide for Ubuntu installation
I’m running a NextCloud and an OnlyOffice Docs server in separate VMs on a Proxmox server.
A third server is providing reverse proxy services using Apache.
The configuration is running, I can open docx and xlsx files in my browser.
The servers are covered by Let’s Encrypt certs and NextCloud confirmed correct keys and certs between itself and the OnlyOffice server.
At first i thought the community edition will be sufficient for my private use, but I really would like to edit files from my android phone so I bought a home license.
I copied the license.lic file to /var/www/onlyoffice/Data
I can’t see if the license is active but it does not seem so as my android still tells me that I’m not allowed to edit files.
How can I activate the license or verify the file was read and accepted?
Both installations (nextcloud, onlyoffice) check out as healthy if I do the tests.
There are things I’ll have to check and correct, as I get some errors about the webserver, but I don’t think this interferes with the license. (see below)
I will fix those errors eventually, but the day only has 24h
Any ideas?
Error Messages from settings/admin/overview
- Your web server is not yet properly set up to allow file synchronization, because the WebDAV interface seems to be broken. To allow this check to run you have to make sure that your webserver can connect to itself. Therefor it must be able to resolve and connect to at least one its
trusted_domains
or theoverwrite.cli.url
Your webserver is not set up to serve
.js.map
files. Without these files, JavaScript Source Maps won’t function properly, making it more challenging to troubleshoot and debug any issues that may arise. -
Could not check for JavaScript support via any of your
trusted_domains
noroverwrite.cli.url
. This may be the result of a server-side DNS mismatch or outbound firewall rule. Please check manually if your webserver serves.mjs
files using the JavaScript MIME type. To allow this check to run you have to make sure that your webserver can connect to itself. Therefor it must be able to resolve and connect to at least one itstrusted_domains
Your web server is not properly set up to resolve “/ocm-provider/”, “/ocs-provider/”. This is most likely related to a web server configuration that was not updated to deliver this folder directly. Please compare your configuration against the shipped rewrite rules in “.htaccess” for Apache or the provided one in the documentation for Nginx. On Nginx those are typically the lines starting with “location ~” that need an update. For more details see the [documentation
] <only 2 links allowed for first post? WHISKEY-TANGO-FOXTROT>.
.well-known
URLs, failed on:/.well-known/webfinger
For more details see the [documentation] <only 2 links allowed for first post? WHISKEY-TANGO-FOXTROT>.
127 errors in the logs since May 10, 2024, 8:00:17 PM
Some headers are not set correctly on your instance - The
X-Robots-Tag
HTTP header is not set tonoindex,nofollow
. This is a potential security or privacy risk, as it is recommended to adjust this setting accordingly. - TheX-Frame-Options
HTTP header is not set tosameorigin
. This is a potential security or privacy risk, as it is recommended to adjust this setting accordingly. - TheX-Permitted-Cross-Domain-Policies
HTTP header is not set tonone
. This is a potential security or privacy risk, as it is recommended to adjust this setting accordingly. - TheX-XSS-Protection
HTTP header does not contain1; mode=block
. This is a potential security or privacy risk, as it is recommended to adjust this setting accordingly. - TheReferrer-Policy
HTTP header is not set tono-referrer
,no-referrer-when-downgrade
,strict-origin
,strict-origin-when-cross-origin
orsame-origin
. This can leak referer information. See the [W3C Recommendation] <only 2 links allowed for first post? WHISKEY-TANGO-FOXTROT>. -
Could not check for WOFF2 loading support. Please check manually if your webserver serves
.woff2
files. To allow this check to run you have to make sure that your webserver can connect to itself. Therefor it must be able to resolve and connect to at least one itstrusted_domains
. For more details see the [documentation] <only 2 links allowed for first post? WHISKEY-TANGO-FOXTROT>.
The database is used for transactional file locking. To enhance performance, please configure memcache, if available. For more details see the [documentation
The PHP module “imagick” in this instance has no SVG support. For better compatibility it is recommended to install it. For more details see the [documentation
