After I started onlyoffice7.5 version in docker, I checked the container log and found the following error:
Hello @luo,
Please specify the version of docker installed on your server. Document Server is compatible only with officially supported docker versions:
Thank you very much for your help. The version I currently installed with docker is 18.09
You need to update your docker.
Okay, I understand, thank you very much
