Hi, I would like see what exactly is the difference between docs-docservice and documentserver docker images. I see that version 9 is present as documentserver but not really as docs-docservice. On the other hand helm chart provided here is using the docs-docservice docker images which means no update possible yet.
Hello @astachowiak,
docs-docservice and docs-converter images are used in a Kubernetes cluster installation of the Document Server. Since cluster installation is a paid feature, the free version of these images won’t be updated. If you have a cluster license, you can use add -de or -ee to the image name (docs-docservice-de etc.) and use the corresponding version.
