Hi,
When I run the docker-compose.yml, I get the following error:
Setting up ca-certificates (20211016ubuntu0.22.04.1) ...
Updating certificates in /etc/ssl/certs...
124 added, 0 removed; done.
Setting up gpgconf (2.2.27-3ubuntu2.1) ...
Setting up gpg (2.2.27-3ubuntu2.1) ...
Setting up libpython3-stdlib:amd64 (3.10.6-1~22.04) ...
Setting up gnupg-utils (2.2.27-3ubuntu2.1) ...
Setting up gpg-agent (2.2.27-3ubuntu2.1) ...
Setting up python3.10 (3.10.6-1~22.04.2) ...
Setting up gpgsm (2.2.27-3ubuntu2.1) ...
Setting up python3 (3.10.6-1~22.04) ...
Setting up dirmngr (2.2.27-3ubuntu2.1) ...
Setting up gpg-wks-server (2.2.27-3ubuntu2.1) ...
Setting up lsb-release (11.1.0ubuntu4) ...
Setting up gpg-wks-client (2.2.27-3ubuntu2.1) ...
Setting up gnupg (2.2.27-3ubuntu2.1) ...
Processing triggers for libc-bin (2.35-0ubuntu3.1) ...
Processing triggers for ca-certificates (20211016ubuntu0.22.04.1) ...
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
gpg: WARNING: unsafe permissions on homedir '/root/.gnupg'
gpg: keyring '/etc/apt/trusted.gpg.d/onlyoffice.gpg' created
gpg: keyserver receive failed: No data
ERROR: Service 'onlyoffice-documentserver' failed to build: The command '/bin/sh -c echo "#!/bin/sh\nexit 0" > /usr/sbin/policy-rc.d && apt-get -y update && apt-get -yq install wget apt-transport-https gnupg locales lsb-release && mkdir -p $HOME/.gnupg && gpg --no-default-keyring --keyring gnupg-ring:/etc/apt/trusted.gpg.d/onlyoffice.gpg --keyserver keyserver.ubuntu.com --recv-keys 0x8320ca65cb2de8e5 && chmod 644 /etc/apt/trusted.gpg.d/onlyoffice.gpg && locale-gen en_US.UTF-8 && echo ttf-mscorefonts-installer msttcorefonts/accepted-mscorefonts-eula select true | debconf-set-selections && wget -O - https://packagecloud.io/install/repositories/rabbitmq/rabbitmq-server/script.deb.sh | bash && if [ $(lsb_release -cs) = focal ]; then RABBITMQ_VERSION=3.8.11-1; else RABBITMQ_VERSION=3.9 ; fi && apt-get -yq install adduser apt-utils bomstrip certbot curl gconf-service htop libasound2 libboost-regex-dev libcairo2 libcurl3-gnutls libcurl4 libgtk-3-0 libnspr4 libnss3 libstdc++6 libxml2 libxss1 libxtst6 mysql-client nano net-tools netcat-openbsd nginx-extras postgresql postgresql-client pwgen rabbitmq-server=${RABBITMQ_VERSION}* redis-server software-properties-common sudo supervisor ttf-mscorefonts-installer xvfb zlib1g && if [ $(ls -l /usr/share/fonts/truetype/msttcorefonts | wc -l) -ne 61 ]; then echo 'msttcorefonts failed to download'; exit 1; fi && echo "SERVER_ADDITIONAL_ERL_ARGS=\"+S 1:1\"" | tee -a /etc/rabbitmq/rabbitmq-env.conf && sed -i "s/bind .*/bind 127.0.0.1/g" /etc/redis/redis.conf && sed 's|\(application\/zip.*\)|\1\n application\/wasm wasm;|' -i /etc/nginx/mime.types && pg_conftool $PG_VERSION main set listen_addresses 'localhost' && service postgresql restart && sudo -u postgres psql -c "CREATE DATABASE $ONLYOFFICE_VALUE;" && sudo -u postgres psql -c "CREATE USER $ONLYOFFICE_VALUE WITH password '$ONLYOFFICE_VALUE';" && sudo -u postgres psql -c "GRANT ALL privileges ON DATABASE $ONLYOFFICE_VALUE TO $ONLYOFFICE_VALUE;" && service postgresql stop && service redis-server stop && service rabbitmq-server stop && service supervisor stop && service nginx stop && rm -rf /var/lib/apt/lists/*' returned a non-zero code: 2
