Do you want to: Problem - Docker Container is redirecting to https://127.0.0.1
Document Server version: docker:latest in podman v4.6.1
OS: AlmaLinux9.3
Browser version: Firefox 115.4.0esr
Hello, I have a fresh install of AlmaLinux 9.3 with a NextCloud (latest) installation running on Apache. Nextcloud runs fine. Now I’m struggeling to get OnlyOffice running correctly. OnlyOffice should run as a location behind Apache configured as a reverseProxy.
First I have created all folders and copied the certs:
mkdir -p /opt/onlyoffice/DocumentServer/{data,db,lib,logs}
mkdir -p /opt/onlyoffice/DocumentServer/data/certs
cp /etc/ssl/private/selfsigned.key /opt/onlyoffice/DocumentServer/data/certs/onlyoffice.key
cp /etc/ssl/certs/selfsigned.pem /opt/onlyoffice/DocumentServer/data/certs/onlyoffice.crt
chown -R 100108:100111 /opt/onlyoffice/DocumentServer/data/certs/
Then installing OnlyOffice Container. I’m using a Dockerfile:
FROM docker.io/onlyoffice/documentserver:latest
RUN sed -i 's/"rejectUnauthorized": true/"rejectUnauthorized": false/' /etc/onlyoffice/documentserver/default.json
…creating a docker image with podman build -t onlyoffice:latest -f Dockerfile
. And starting a new Container with:
podman run -i -t -d -p 8888:80 --name=onlyoffice -e JWT_SECRET=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx -e USE_UNAUTHORIZED_STORAGE=true --add-host nextcloud.example.org:10.0.100.30 -v /opt/onlyoffice/DocumentServer/logs:/var/log/onlyoffice:Z -v /opt/onlyoffice/DocumentServer/data:/var/www/onlyoffice/Data:Z -v /opt/onlyoffice/DocumentServer/lib:/var/lib/onlyoffice:Z -v /opt/onlyoffice/DocumentServer/db:/var/lib/postgresql:Z -u root onlyoffice:latest
I’ve setted up the apache vHost like suggested in the OnlyOffice documentation:
<VirtualHost *:80>
ServerName nextcloud.example.org
RewriteEngine On
RewriteRule ^(.*)$ https://%{HTTP_HOST}$1 [R=302,L]
</VirtualHost>
<VirtualHost *:443>
DocumentRoot /var/www/vhosts/nextcloud.example.org/nextcloud
# SSL Settings
SSLEngine on
SSLCertificateFile /etc/ssl/certs/selfsigned.pem
SSLCertificateKeyFile /etc/ssl/private/selfsigned.key
# enable HTTP/2, if available
Protocols h2 http/1.1
CustomLog /var/log/httpd/nextcloud.example.org-access.log combined
ErrorLog /var/log/httpd/nextcloud.example.org-error.log
<Directory /var/www/vhosts/nextcloud.example.org/nextcloud>
AllowOverride all
Options -Indexes
</Directory>
Header always set Strict-Transport-Security "max-age=63072000"
#### OnlyOffice
Define VPATH /very-long-and-secret-string
Define DS_ADDRESS 127.0.0.1:8888
<Location ${VPATH}>
Require all granted
SetEnvIf Host "^(.*)$" THE_HOST=$1
RequestHeader setifempty X-Forwarded-Proto http
RequestHeader setifempty X-Forwarded-Host %{THE_HOST}e
RequestHeader edit X-Forwarded-Host (.*) $1${VPATH}
ProxyAddHeaders Off
</Location>
RewriteEngine on
RewriteCond %{HTTP:Upgrade} websocket [NC]
RewriteCond %{HTTP:Connection} upgrade [NC]
RewriteRule ^\${VPATH}/?(.*) "ws://${DS_ADDRESS}/$1" [P,L]
ProxyPass ${VPATH} "http://${DS_ADDRESS}"
ProxyPassReverse ${VPATH} "http://${DS_ADDRESS}"
</VirtualHost>
When I now open http://nextcloud.example.org/very-long-and-secret-string I always get redirected to https://127.0.0.1
Just to know: The Server runs not public yet, so I only have edited my local hosts file:
10.0.100.30 nextcloud.example.org
Can anyone Help?
