Display number when input Chinese Pinyin in "Find"
OS version: IOS 15.7
App version: 7.2
Mode: On Device
When using the “Find” function, the situation in the picture will appear after entering the Chinese text. This situation also occurs in .docx and .pttx files, but this function works fine on .pdf files.
Steps
  1. Enter Onlyoffice document on mobile
  2. Using the “Find” function
  3. Switch input method to Chinese Pinyin
  4. Input any key
Hello!
Thanks for reporting this issue.
We have investigated it and found out that this is a bug. We have registered this bug under number 59594. We will try to fix it in the next versions of ONLYOFFICE Documents.
