Disconnenct docserver everyday
Help
I installed the document server on a separate virtual machine, NexCloud on another virtual machine. I managed to make them friends. It was possible to open and edit documents from NexCloud. But now every day the connection to the document server is interrupted in the NexCloud settings. If I try to connect it with the specified parameters, no errors occur. The /var/log/onlyoffice/documentserver/docservice/out.log log shows that the license has expired “[2025-02-17T06:54:55.718] [WARN] [localhost] [docId] [userId] nodeJS - notifyLicenseExpiration(): expiration date is not defined”
Hello @Origimato,
Please provide the following additional info:
  1. The version of the Document Server that you are using
  2. The version of Nextcloud
  3. The version of Onlyoffice Connector’s App for Nextcloud
  4. Nextcloud logs: Administration Settings → Logging
  5. Full Document Server logs as file after the issue reoccurs
Hello
Thank for your answer
My version
NexCloud 29.0.8
OnlyOffice DocServer Package: onlyoffice-documentserver Version: 8.3.0-94
Connector’s App for Nextcloud 8.2.2.22
Logs from nexcloud
{"reqId":"zlSdJKExE8OyKsYOBepH","level":3,"time":"2025-02-17T14:53:45+00:00","remoteAddr":"195.206.244.244","user":"--","app":"onlyoffice","method":"GET","url":"/nextcloud/index.php/apps/files_sharing/publicpreview/NgL3Mss6eF6tyRP?fileId=519391&file=%2F%D0%94%D0%B5%D0%BA%D0%B0%D0%B1%D1%80%D1%8C%202024%2FSummary%2F%D0%90%D0%BA%D1%82%D1%83%D0%B0%D0%BB%D1%8C%D0%BD%D1%8B%D0%B5%20%D0%B2%D0%B5%D1%80%D1%81%D0%B8%D0%B8%20%D0%BE%D1%82%2005.02.25%2F%D0%9B%D0%B0%D0%B2_Summary_2024_12.xlsm&c=6d4aed124c1cda03541cf3b5bd7e0f97&x=250&y=250","message":"getConvertedUri: from xlsm to jpeg","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36","version":"29.0.8.1","exception":{"Exception":"GuzzleHttp\\Exception\\ServerException","Message":"Server error: `POST https://onlyoffice.nmg.corp/ConvertService.ashx` resulted in a `504 Gateway Time-out` response:\n<html>\r\n<head><title>504 Gateway Time-out</title></head>\r\n<body>\r\n<center><h1>504 Gateway Time-out</h1></center>\r\n<hr><c (truncated...)\n","Code":504,"Trace":[{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":72,"function":"create","class":"GuzzleHttp\\Exception\\RequestException","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":204,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":153,"function":"callHandler","class":"GuzzleHttp\\Promise\\Promise","type":"::"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/TaskQueue.php","line":48,"function":"GuzzleHttp\\Promise\\{closure}","class":"GuzzleHttp\\Promise\\Promise","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":248,"function":"run","class":"GuzzleHttp\\Promise\\TaskQueue","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":224,"function":"invokeWaitFn","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":269,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":226,"function":"invokeWaitList","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":62,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":189,"function":"wait","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Http/Client/Client.php","line":301,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":388,"function":"post","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":193,"function":"request","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":100,"function":"sendRequestToConvertService","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/Preview.php","line":271,"function":"getConvertedUri","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/ProviderV1Adapter.php","line":53,"function":"getThumbnail","class":"OCA\\Onlyoffice\\Preview","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/GeneratorHelper.php","line":64,"function":"getThumbnail","class":"OC\\Preview\\ProviderV1Adapter","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":361,"function":"getThumbnail","class":"OC\\Preview\\GeneratorHelper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":337,"function":"generateProviderPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":143,"function":"getMaxPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":110,"function":"generatePreviews","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/PreviewManager.php","line":190,"function":"getPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_sharing/lib/Controller/PublicPreviewController.php","line":134,"function":"getPreview","class":"OC\\PreviewManager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":232,"function":"getPreview","class":"OCA\\Files_Sharing\\Controller\\PublicPreviewController","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":138,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":331,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/html/nextcloud/lib/base.php","line":1058,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":49,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Exception/RequestException.php","Line":113,"message":"getConvertedUri: from xlsm to jpeg","CustomMessage":"getConvertedUri: from xlsm to jpeg"}}
{"reqId":"8rWo5EsOBkS5oRoWgKUc","level":3,"time":"2025-02-17T14:53:46+00:00","remoteAddr":"195.206.244.244","user":"--","app":"onlyoffice","method":"GET","url":"/nextcloud/index.php/apps/files_sharing/publicpreview/NgL3Mss6eF6tyRP?fileId=519399&file=%2F%D0%94%D0%B5%D0%BA%D0%B0%D0%B1%D1%80%D1%8C%202024%2FSummary%2F%D0%90%D0%BA%D1%82%D1%83%D0%B0%D0%BB%D1%8C%D0%BD%D1%8B%D0%B5%20%D0%B2%D0%B5%D1%80%D1%81%D0%B8%D0%B8%20%D0%BE%D1%82%2005.02.25%2F%D0%A7%D0%95_Summary_2024_12_.xlsm&c=f4d5d620e33289eb370f9b51ced3c6af&x=250&y=250","message":"getConvertedUri: from xlsm to jpeg","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36","version":"29.0.8.1","exception":{"Exception":"GuzzleHttp\\Exception\\ServerException","Message":"Server error: `POST https://onlyoffice.nmg.corp/ConvertService.ashx` resulted in a `504 Gateway Time-out` response:\n<html>\r\n<head><title>504 Gateway Time-out</title></head>\r\n<body>\r\n<center><h1>504 Gateway Time-out</h1></center>\r\n<hr><c (truncated...)\n","Code":504,"Trace":[{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":72,"function":"create","class":"GuzzleHttp\\Exception\\RequestException","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":204,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":153,"function":"callHandler","class":"GuzzleHttp\\Promise\\Promise","type":"::"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/TaskQueue.php","line":48,"function":"GuzzleHttp\\Promise\\{closure}","class":"GuzzleHttp\\Promise\\Promise","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":248,"function":"run","class":"GuzzleHttp\\Promise\\TaskQueue","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":224,"function":"invokeWaitFn","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":269,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":226,"function":"invokeWaitList","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":62,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":189,"function":"wait","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Http/Client/Client.php","line":301,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":388,"function":"post","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":193,"function":"request","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":100,"function":"sendRequestToConvertService","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/Preview.php","line":271,"function":"getConvertedUri","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/ProviderV1Adapter.php","line":53,"function":"getThumbnail","class":"OCA\\Onlyoffice\\Preview","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/GeneratorHelper.php","line":64,"function":"getThumbnail","class":"OC\\Preview\\ProviderV1Adapter","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":361,"function":"getThumbnail","class":"OC\\Preview\\GeneratorHelper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":337,"function":"generateProviderPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":143,"function":"getMaxPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":110,"function":"generatePreviews","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/PreviewManager.php","line":190,"function":"getPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_sharing/lib/Controller/PublicPreviewController.php","line":134,"function":"getPreview","class":"OC\\PreviewManager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":232,"function":"getPreview","class":"OCA\\Files_Sharing\\Controller\\PublicPreviewController","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":138,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":331,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/html/nextcloud/lib/base.php","line":1058,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":49,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Exception/RequestException.php","Line":113,"message":"getConvertedUri: from xlsm to jpeg","CustomMessage":"getConvertedUri: from xlsm to jpeg"}}
{"reqId":"LQtmOTT67kt37ZwDsQDA","level":3,"time":"2025-02-17T15:37:44+00:00","remoteAddr":"195.206.244.246","user":"--","app":"onlyoffice","method":"GET","url":"/nextcloud/index.php/apps/files_sharing/publicpreview/KF8m7NWrKL6cy4m?fileId=517726&file=%2F%D0%A2%D0%B0%D1%80%D0%B3%D0%B5%D1%82%2F%D0%9A%D0%BE%D0%BF%D0%B8%D1%8F%20Riki_Group_Model_October_2022_INTERNAL_v3%20%2800000004%29.xlsx&c=361ea10d9af26651b149ff798c1b3cb2&x=250&y=250","message":"getConvertedUri: from xlsx to jpeg","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.1 Safari/605.1.15","version":"29.0.8.1","exception":{"Exception":"GuzzleHttp\\Exception\\ServerException","Message":"Server error: `POST https://onlyoffice.nmg.corp/ConvertService.ashx` resulted in a `504 Gateway Time-out` response:\n<html>\r\n<head><title>504 Gateway Time-out</title></head>\r\n<body>\r\n<center><h1>504 Gateway Time-out</h1></center>\r\n<hr><c (truncated...)\n","Code":504,"Trace":[{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":72,"function":"create","class":"GuzzleHttp\\Exception\\RequestException","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":204,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":153,"function":"callHandler","class":"GuzzleHttp\\Promise\\Promise","type":"::"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/TaskQueue.php","line":48,"function":"GuzzleHttp\\Promise\\{closure}","class":"GuzzleHttp\\Promise\\Promise","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":248,"function":"run","class":"GuzzleHttp\\Promise\\TaskQueue","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":224,"function":"invokeWaitFn","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":269,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":226,"function":"invokeWaitList","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":62,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":189,"function":"wait","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Http/Client/Client.php","line":301,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":388,"function":"post","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":193,"function":"request","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":100,"function":"sendRequestToConvertService","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/Preview.php","line":271,"function":"getConvertedUri","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/ProviderV1Adapter.php","line":53,"function":"getThumbnail","class":"OCA\\Onlyoffice\\Preview","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/GeneratorHelper.php","line":64,"function":"getThumbnail","class":"OC\\Preview\\ProviderV1Adapter","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":361,"function":"getThumbnail","class":"OC\\Preview\\GeneratorHelper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":337,"function":"generateProviderPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":143,"function":"getMaxPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":110,"function":"generatePreviews","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/PreviewManager.php","line":190,"function":"getPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_sharing/lib/Controller/PublicPreviewController.php","line":134,"function":"getPreview","class":"OC\\PreviewManager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":232,"function":"getPreview","class":"OCA\\Files_Sharing\\Controller\\PublicPreviewController","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":138,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":331,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/html/nextcloud/lib/base.php","line":1058,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":49,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Exception/RequestException.php","Line":113,"message":"getConvertedUri: from xlsx to jpeg","CustomMessage":"getConvertedUri: from xlsx to jpeg"}}
{"reqId":"wFyQx3cKPYXBjb5DBMGG","level":3,"time":"2025-02-17T15:37:45+00:00","remoteAddr":"195.206.244.246","user":"--","app":"onlyoffice","method":"GET","url":"/nextcloud/index.php/apps/files_sharing/publicpreview/KF8m7NWrKL6cy4m?fileId=517741&file=%2F%D0%A2%D0%B0%D1%80%D0%B3%D0%B5%D1%82%2F%D0%A4%D0%B8%D0%BD%D0%B0%D0%BD%D1%81%D0%BE%D0%B2%D1%8B%D0%B5%20%D0%BF%D0%BE%D0%BA%D0%B0%D0%B7%D0%B0%D1%82%D0%B5%D0%BB%D0%B8%202021-2022%20%2B%20%D0%BF%D1%80%D0%BE%D0%B3%D0%BD%D0%BE%D0%B7%20%2B%20cash%20flow%20%28clean%29.xlsx&c=02c3fee5b68af43b88bbfeb55ce12755&x=250&y=250","message":"getConvertedUri: from xlsx to jpeg","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.1 Safari/605.1.15","version":"29.0.8.1","exception":{"Exception":"GuzzleHttp\\Exception\\ServerException","Message":"Server error: `POST https://onlyoffice.nmg.corp/ConvertService.ashx` resulted in a `504 Gateway Time-out` response:\n<html>\r\n<head><title>504 Gateway Time-out</title></head>\r\n<body>\r\n<center><h1>504 Gateway Time-out</h1></center>\r\n<hr><c (truncated...)\n","Code":504,"Trace":[{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":72,"function":"create","class":"GuzzleHttp\\Exception\\RequestException","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":204,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":153,"function":"callHandler","class":"GuzzleHttp\\Promise\\Promise","type":"::"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/TaskQueue.php","line":48,"function":"GuzzleHttp\\Promise\\{closure}","class":"GuzzleHttp\\Promise\\Promise","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":248,"function":"run","class":"GuzzleHttp\\Promise\\TaskQueue","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":224,"function":"invokeWaitFn","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":269,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":226,"function":"invokeWaitList","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":62,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":189,"function":"wait","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Http/Client/Client.php","line":301,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":388,"function":"post","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":193,"function":"request","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":100,"function":"sendRequestToConvertService","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/Preview.php","line":271,"function":"getConvertedUri","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/ProviderV1Adapter.php","line":53,"function":"getThumbnail","class":"OCA\\Onlyoffice\\Preview","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/GeneratorHelper.php","line":64,"function":"getThumbnail","class":"OC\\Preview\\ProviderV1Adapter","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":361,"function":"getThumbnail","class":"OC\\Preview\\GeneratorHelper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":337,"function":"generateProviderPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":143,"function":"getMaxPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":110,"function":"generatePreviews","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/PreviewManager.php","line":190,"function":"getPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_sharing/lib/Controller/PublicPreviewController.php","line":134,"function":"getPreview","class":"OC\\PreviewManager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":232,"function":"getPreview","class":"OCA\\Files_Sharing\\Controller\\PublicPreviewController","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":138,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":331,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/html/nextcloud/lib/base.php","line":1058,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":49,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Exception/RequestException.php","Line":113,"message":"getConvertedUri: from xlsx to jpeg","CustomMessage":"getConvertedUri: from xlsx to jpeg"}}
{"reqId":"MlBzKxxdOMzrM7NCEdjq","level":3,"time":"2025-02-17T15:37:45+00:00","remoteAddr":"195.206.244.246","user":"--","app":"onlyoffice","method":"GET","url":"/nextcloud/index.php/apps/files_sharing/publicpreview/KF8m7NWrKL6cy4m?fileId=517747&file=%2F%D0%A2%D0%B0%D1%80%D0%B3%D0%B5%D1%82%2F%D0%A4%D0%B8%D0%BD%D0%B0%D0%BD%D1%81%D0%BE%D0%B2%D1%8B%D0%B5%20%D0%BF%D0%BE%D0%BA%D0%B0%D0%B7%D0%B0%D1%82%D0%B5%D0%BB%D0%B8%202021-2022%20%2B%20%D0%BF%D1%80%D0%BE%D0%B3%D0%BD%D0%BE%D0%B7%20%2B%20cash%20flow.xlsx&c=1c908b33a9d2df58fd9f9f53445a0008&x=250&y=250","message":"getConvertedUri: from xlsx to jpeg","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.1 Safari/605.1.15","version":"29.0.8.1","exception":{"Exception":"GuzzleHttp\\Exception\\ServerException","Message":"Server error: `POST https://onlyoffice.nmg.corp/ConvertService.ashx` resulted in a `504 Gateway Time-out` response:\n<html>\r\n<head><title>504 Gateway Time-out</title></head>\r\n<body>\r\n<center><h1>504 Gateway Time-out</h1></center>\r\n<hr><c (truncated...)\n","Code":504,"Trace":[{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":72,"function":"create","class":"GuzzleHttp\\Exception\\RequestException","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":204,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":153,"function":"callHandler","class":"GuzzleHttp\\Promise\\Promise","type":"::"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/TaskQueue.php","line":48,"function":"GuzzleHttp\\Promise\\{closure}","class":"GuzzleHttp\\Promise\\Promise","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":248,"function":"run","class":"GuzzleHttp\\Promise\\TaskQueue","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":224,"function":"invokeWaitFn","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":269,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":226,"function":"invokeWaitList","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":62,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":189,"function":"wait","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Http/Client/Client.php","line":301,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":388,"function":"post","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":193,"function":"request","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":100,"function":"sendRequestToConvertService","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/Preview.php","line":271,"function":"getConvertedUri","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/ProviderV1Adapter.php","line":53,"function":"getThumbnail","class":"OCA\\Onlyoffice\\Preview","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/GeneratorHelper.php","line":64,"function":"getThumbnail","class":"OC\\Preview\\ProviderV1Adapter","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":361,"function":"getThumbnail","class":"OC\\Preview\\GeneratorHelper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":337,"function":"generateProviderPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":143,"function":"getMaxPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":110,"function":"generatePreviews","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/PreviewManager.php","line":190,"function":"getPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_sharing/lib/Controller/PublicPreviewController.php","line":134,"function":"getPreview","class":"OC\\PreviewManager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":232,"function":"getPreview","class":"OCA\\Files_Sharing\\Controller\\PublicPreviewController","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":138,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":331,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/html/nextcloud/lib/base.php","line":1058,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":49,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Exception/RequestException.php","Line":113,"message":"getConvertedUri: from xlsx to jpeg","CustomMessage":"getConvertedUri: from xlsx to jpeg"}}
{"reqId":"gEO05DZUac2425NwyInh","level":3,"time":"2025-02-17T18:50:07+00:00","remoteAddr":"","user":"--","app":"onlyoffice","method":"","url":"--","message":"getConvertedUri on check error","userAgent":"--","version":"29.0.8.1","exception":{"Exception":"Exception","Message":"Error occurred in the document service: Error while downloading the document file to be converted.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":104,"function":"processConvServResponceError","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":452,"function":"getConvertedUri","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/Cron/EditorsCheck.php","line":155,"function":"checkDocServiceUrl","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/lib/public/BackgroundJob/Job.php","line":80,"function":"run","class":"OCA\\Onlyoffice\\Cron\\EditorsCheck","type":"->"},{"file":"/var/www/html/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":102,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/var/www/html/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":92,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->"},{"file":"/var/www/html/nextcloud/cron.php","line":177,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->"}],"File":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","Line":257,"message":"getConvertedUri on check error","CustomMessage":"getConvertedUri on check error"}}
{"reqId":"ue1jV3HHZ5BxNbxvoqnb","level":3,"time":"2025-02-18T09:53:44+00:00","remoteAddr":"10.100.35.30","user":"--","app":"public","method":"GET","url":"/.well-known/webfinger","message":"The requested uri(/.well-known/webfinger) cannot be processed by the script '/nextcloud/public.php')","userAgent":"Nextcloud Server Crawler","version":"29.0.8.1","exception":{"Exception":"Exception","Message":"The requested uri(/.well-known/webfinger) cannot be processed by the script '/nextcloud/public.php')","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Request.php","line":769,"function":"getRawPathInfo","class":"OC\\AppFramework\\Http\\Request","type":"->"},{"file":"/var/www/html/nextcloud/public.php","line":69,"function":"getPathInfo","class":"OC\\AppFramework\\Http\\Request","type":"->"}],"File":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Request.php","Line":743,"message":"The requested uri(/.well-known/webfinger) cannot be processed by the script '/nextcloud/public.php')","exception":{},"CustomMessage":"The requested uri(/.well-known/webfinger) cannot be processed by the script '/nextcloud/public.php')"}}
Logs from onlyoffice
[2025-02-18T06:54:55.719] [WARN] [localhost] [docId] [userId] nodeJS - notifyLicenseExpiration(): expiration date is not defined
/var/log/onlyoffice/documentserver/converter/out.log
[2025-02-18T06:54:53.498] [WARN] [localhost] [docId] [userId] nodeJS - num of CPUs: 2; availableParallelism: undefined
[2025-02-18T06:54:53.499] [WARN] [localhost] [docId] [userId] nodeJS - update cluster with 1 workers
Please still provide all Document Server logs as archive file (you can send them via PM if it is more convenient for you)
Hi Dmitrii
I replied to your email
Please respond here or via personal message to my profile (click on the profile picture → click on Message), not to the email
Please do the following steps:
  1. Update your Nextcloud Connector to the latest version (9.6.0)
  2. Specify your Nextcloud address in the “Advanced server settings” section of the connector options (the last field there). Save the changes.
  3. If it doesn’t help, turn off the background check by editing Nextcloud’s config file (/nextcloud/config/config.php)
'onlyoffice' => array
'editors_check_interval' => 0
Should my configuration in the onlyoffice section look like this?
  'onlyoffice' =>
  array (
    'docs_server' => 'https://onlyoffice/',
    'jwt_secret' => 'code',
    'jwt_header' => 'code',
UPD. I did as you said. I’ll check tomorrow, when the document server usually disconnects from NexCloud
Good afternoon Dmitry.
Well, a day has passed, the document server has not yet disconnected from NexCloud. I’ll keep an eye on it and give you information tomorrow. Looks like it’s working
Alright, please notify if the issue reoccurs
