Disable numeric and bulleted list
Hello.
I was wondering if there is a way to programmatically disable these options, or just have them off by default
imagen
These options can be located at :
File → Advanced Settings → AutoCorrect Options → AutoFormat as you type
Thanks.
Hello @edlacer
Sorry, there’s no way to programmatically change these options. To be honest, I’m not sure that I understand the final goal of such actions. Once these settings have been changed, they persist for user’s browser\PC. So a user doesn’t need to change these settings each time they are working with files.
