Hi. I have an account with OnlyOffice. I am unable to access my account because my phone was water damaged and I use a non-cloud based Authenticator App. Is it at all possible to disable 2FA so I can login?
Note I am the only one on the account.
Hey @amanajosh
In the profile settings, there should be 5 backup codes in case you lose your authenticator.
If cookies are saved in any browser, you can reset the authenticator.
DM me your portal address.
Let’s see what we can do about it.
I was stupid enough not to obtain the backup codes so you may need to help me disable 2FA.
Not sure what the portal address is. Um there’s this: amanajosh@skiff.com
Right) I mean you url portal addres
I am dealing with your problem.
@amanajosh
2FA has been disabled. Please check the login possibility.
Hi @amanajosh
Please clarify if there is still a problem?
Sorry. All good. Logged In
So, let’s summarize.
If you have lost your authenticator:
[Next part for Workspace Cloud]
(You can write here or to the email support@onlyoffice.com)
